Oil Filter From Hell - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 05-13-2006, 08:20 PM   #1 (permalink)
View iMagnusX's Photo Gallery
OK, so I thought I would be a nice son and clean my mom's 1997 Toyota Avalon and change the oil. So I drain the oil, and then I run into the worst designed oil filter placement in the world. Far worse than the B14. I try to take it off with one of those filter tools, but it doesn't budge. I get desperate, and start trying to cut it open to get some leverage on it or something, and this is what I've ended up with.
Sorry, I would've taken a few more pictures but the camera just ran out of batteries.
If you've got any idea of what to do, then HELP.
Also, which way do you turn to loosen the filter?
Thanks.
iMagnusX is offline   Reply With Quote
Old 05-14-2006, 02:14 AM   #2 (permalink)
Offical TN Hillbilly
TcmaBoy's Avatar
View TcmaBoy's Photo Gallery
Lefty loosey, rightey tightey. Hard to say. I don't know how much room you have to work with. Get some vice grips and grab the lip of the filter. Get a hammer and hit the vice grips. Hmmm...get some thick leather gloves, grab that bad boy and twist like hell. The sharp edges will dig into your gloves and give you some grip(as well as keep you from busting your knuckles if it comes loose).
Don't you SAS me boy.
Please wheel responsibly.
TcmaBoy is offline   Reply With Quote
Old 05-14-2006, 04:34 PM   #3 (permalink)
That Acura Guy
TTercel's Avatar
Gameroom cash: $267565
View TTercel's Photo Gallery
Damn that bad boy sure doesnt want to come off. Who ever did the oil change last time should get hell. They prob tightened it up too tight and used a tool and never put oil on the oil filter seal. Follow TcmaBoy's advice. The worst filter placement that i have seen is on the Caddilacs. They have them upside down so when ever you take it off oil will spil all over the engine.
TTercel is offline   Reply With Quote
Old 05-14-2006, 04:49 PM   #4 (permalink)
I got free tires
MikeX's Avatar
View MikeX's Photo Gallery
A strap wrench might work if there's anything circular to grab.
X-Runner
MikeX is offline   Reply With Quote
Old 05-14-2006, 06:18 PM   #5 (permalink)
Stevie_Ray's Avatar
View Stevie_Ray's Photo Gallery
Thanks.
You gotta be kidding???!!!!!!!!!! That's probably your problem, you are tightening it when you think you are loosening it.
Lefty-loosey, righty-tighty.
When under a car use this. I do quite often. Use the 'right hand rule'. Using you right hand, the thumb will point the direction you want the nut to go, your fingers will point in the direction to turn.
I'm sorry but that's probably the stupidest thing I ever heard on a "car" site.
Stevie_Ray is offline   Reply With Quote
Old 05-14-2006, 11:44 PM   #6 (permalink)
I KNOW. I was definately thinking lefty-loosy righty-tighty and then my dad told me "the oil filter is the bolt that goes onto the nut" in a sense, which is true if you think about it. He then told me that because of this, it's backwards. I visualized it, demonstrated it with a regular nut and bolt, to show that it's the same both ways. He's still unsure. I am a n00b. This question may go down in history for stupidity. But uh... don't pin it on me please.
I tried in vain with those circular wrenches for a long time. I'm gonna go look for one of those cap-type filter wrenches that use a socket wrench. With the limited space, that might do the trick. The vise-grips sound like a good idea too (gloves so far didn't cut it). Thanks guys.
Old 05-15-2006, 01:59 AM   #7 (permalink)
SiennaSC98's Avatar
View SiennaSC98's Photo Gallery
This strap oil filter wrench is perfect for those stubborn oil filters; http://www.griotsgarage.com/catalog.jsp?&SKU=FU46CL
SiennaSC98 is offline   Reply With Quote
Old 05-15-2006, 04:16 AM   #8 (permalink)
Noob :-)
View ST185's Photo Gallery
It just like openning a jar, replacing light bulb, removing a gas cap, and 99% of the stuff in this world.
Worst case scenario, remove the exhaust manifold and you should have more room to play with it.
By the way, I've never thought that someone will complain about changing the filter on Toyota V6.
You should see the oil filter on the 3sgte on the my Celica.
Trust me, my wife's 1mzfe is 10 times easier.
I don't even have enough room to turn a ratchet, let alone using other fancy tools.
93 ST185
ST185 is offline   Reply With Quote
Old 05-15-2006, 10:23 AM   #9 (permalink)
I don't even see the filter. Is it to the right of the alternator, behind the oil dipstick?
Oh and this should take about 5 quarts right?
Old 05-15-2006, 11:43 AM   #10 (permalink)
Noob :-)
You are right. That's the filter. It takes a hell of a maneuver to get the oil filter wrench in that. Otherwise, alternator duct (both rubber and the metal one with heat wrap), dipstick, O2 sensor must come off first. And it'll take a special maneuver to get the alternator duct (one with heat wrap) out consider that there are 2 nuts on the bottom side.
But yes, yours should take about 4.5 quarts.
93 ST185
Old 05-15-2006, 05:16 PM   #11 (permalink)
YUP all done. That cup-type filter wrench really did the trick. I think I might get a short, stubby wrench to make it easier though. Thanks guys.
Old 05-19-2006, 01:18 AM   #12 (permalink)
Sebastian Loebs evil twin
BakaWill's Avatar
View BakaWill's Photo Gallery
ah you shoulda just used the gun show on it, lol glad you got it off tho
1990 camry dx 3s-fe
BakaWill is offline   Reply With Quote
Old 09-09-2006, 01:51 AM   #13 (permalink)
View josefm93's Photo Gallery
have you seen how hard to change the filter on 88 89 mr2 sc...
you cannot see the filter...just feel it....ahhhhhhh
josefm93 is offline   Reply With Quote
Old 09-09-2006, 08:48 AM   #14 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
One thing you also could have done was jam a long screwdriver through it (since you'd massacred it already, anyway ) That's an old hillbilly trick. Glad you got it off -- I saw that first picture before reading the story and was thinking, "oh jeez, did they drive like that?"
-- Jonathan W.
http://fleshy.org.nz/
brink is offline   Reply With Quote
Old 09-09-2006, 01:11 PM   #15 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
when I first saw the pic I thought it exploded :O I was like WOAH!
then I thought omg from good son to hated one since she couldn't drive her car until this was resolved lol
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
2005 Avalon XL Oil Filter anndel 3rd Generation (2005-2012) 9 04-01-2008 06:04 PM
Remote Oil Filter? Overwork pump? Go 4x 1st Generation (1995.5–2004) 4 02-15-2006 12:26 PM
Full synthetic motor oil - 32¢ /quart + 1 oil filter ... Pep Boys skewe General Discussion 7 01-19-2006 03:31 PM
Solara 5S-FE oil filter removing. (Dumb) SolaraTRD Solara 20 01-24-2005 11:54 AM
Oil Filter FrankXT86 Camry & Solara Lounge 4 11-10-2004 08:31 PM
