Question about balance shafts - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 02-22-2003, 04:53 PM   #1 (permalink)
View JonWithTheCamry's Photo Gallery
I am guessing that since the balance shaft counter balances the engine then it will have to be timed properly. If anyone knows how to do this then i would greatly appreciate it if you could describe this process.
thanks
JonWithTheCamry is offline   Reply With Quote
Old 02-22-2003, 06:02 PM   #2 (permalink)
aka doublezero...
View wunderboy's Photo Gallery
what are ya drive'n there bro?
There are those who do things, and those who take credit... The trick is to be in the first group, there is a lot less compitition.
wunderboy is offline   Reply With Quote
Old 02-22-2003, 08:09 PM   #3 (permalink)
95 camry 5sfe
Old 02-22-2003, 09:47 PM   #4 (permalink)
PowerHouse Turbo
View JWatson's Photo Gallery
Jon,
First off you MUST have the correct Toyota repair manual to
setup the balance shaft assembly, not to mention the correct
measuring tools. If you don't feel comfortable doing this....take
the engine block and balancer to a Toyota dealer and have them
do it for you. Once you see the repair manual, you'll see what I'm talking about.
The adjusting shims are sold in something like 20
different sizes and this procedure is still difficult even for an experienced Toyota technician.
I can't tell you how many phone call we receive from competent
shops that still have a hard time with proper set-up.
Call me if you need me to fax a few pages to you.
Jeff Watson
www.toyotaworld.com
JWatson is offline   Reply With Quote
Old 02-25-2003, 03:42 PM   #5 (permalink)
Is this repair manual the one from the Toyota dealership or is there a specific one?
Old 02-25-2003, 10:14 PM   #6 (permalink)
PowerHouse Turbo
The Toyota manual is the only book worth having...any others
are a waste of money IMO.
Old 02-26-2003, 06:15 PM   #7 (permalink)
If I decide to just leave the balance shaft off, will this be ok? From what I've seen it is ok to go without it but i dont know what to do about the oil line going to it. Should it be plugged or just left alone. Thanks for all the information.
Old 02-27-2003, 04:23 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
From what I understand the balance shaft helps dampen engine vibrations.
So I would say its okay to leave it off if you want.
Oil line?
I didn't see any oil lines from the one I removed on my buddies 5S-FE. Unless your talking about the oil pickup that bolts onto the corner of the block.
"Skoolin' the unlearned!"
Old 02-27-2003, 06:50 AM   #9 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Well it does add to engine life. Plus your engine is gonna shake like a mofo.
Old 02-28-2003, 03:19 PM   #10 (permalink)
Well i decide to just leave the balance shaft off. I couldnt decide whether to plug the hole or leave it open so I bought a plug and put a small hole in it to restrict the flow. I definatley notice more vibration but its not really bad. At the worst point I can hear the hangtag on my reaview mirror vibrate. I dont know if it added anymore power because im still breaking in the engine.
Old 04-11-2003, 06:56 PM   #11 (permalink)
View zenon's Photo Gallery
balance shafts are there for NVH, they won't reduce engine life in any way.
how much does it weigh?
zenon is offline   Reply With Quote
Old 04-16-2003, 04:58 PM   #12 (permalink)
the whole unit weighs about 15 pounds.
Old 04-16-2003, 05:22 PM   #13 (permalink)
care to check back once everything's broken in? That should make a big difference in the lower gears and rev-matching if it's std.
Old 04-16-2003, 07:58 PM   #14 (permalink)
Id love to do that but if you read my other post you'll see that i cant. the engine is out again
