swap - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 05-27-2006, 04:22 PM   #1 (permalink)
View purposebuilt's Photo Gallery
Canada swap
Hello
I'm not sure if this is where this topic should go but i just wanted to know if anyone here has done an auto to manual swap on a 1985 corolla sr5 and if so can you please advise me on what i will need to complete this swap.
I'm looking to purchase a 4age with tranny for the car.i just want to know what else i'd need like if the tranny is hydro or cable etc...
purposebuilt is offline   Reply With Quote
Old 05-28-2006, 01:17 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
You will need the shifter and cables, the brake pedal assembly, the clutch pedal assembly and the brake master cylinder with it's line to the slave cylinder. You will need to make holes to mount the brake master cylinder most likely. Then hope you have the brackets and clips for mounting those parts. Check with a salvage yard to see if the axles will need to be swapped, though I think they will be ok.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
4age 20v vs b18 swap good_old_geo Archived Corolla threads 15 08-28-2006 07:37 PM
20V Swap, can someone help? -HiTMaN- Archived Corolla threads 8 02-24-2006 05:02 PM
3EE to 5EFE engine swap DaBomb77 Tercel, Paseo, Starlet, and Sera Forum 2 08-20-2005 10:51 AM
1992 Toyota MR2 Swap eMcEeNeSs MR2 Forum 7 07-26-2004 10:20 AM
ATTN: speedemn - Yoshio Engine Swap Ratko Camry & Solara Lounge 4 12-28-2001 04:22 PM
