BenG - You're on a right track to begin with.
Scrub radius has nothing to do with slip angle. There are literally several dozens of very good websites explaining suspension geometry. Just punch in those keywords in google search engine and you'll find more info.
In short; Yes, installing wheels which centerline is more outward than oem wheels (i.e. less offset) are, makes more positive scrub radius. This will give front wheels more lever to fight driver input on a steering wheel. Do this on a several hundred horsepower fwd car, and you'll be scared to let a hand off steering wheel for changing a gear.
Vast positive scrub radius makes steering wheel to jolt side to side under heavy braking. (Well, not necessarily - but it would be able to do so if road surface traction variations encourace such phenomena.)
In recent years megadollar super sportscars (Maserati, Bugatti, Ferrari, Lamborghini...) have started to use negative scrub radius to lessen said ill behaviour.
Heh, nice comment there on assumed Camber variation with altered wheel ET's. I don't wish to start an argument, but it isn't so. Camber will remain unchanged, no matter what ET wheel is installed on a car. Period.
In brief - to maintain oem scrub radius, keep to original ET value, but feel free to bolt on a wider wheel if such is felt to be a necessity.
People who say wheel ET (=offset) should be changed to lower value for wider tyres to fit comfortably - they have no idea of scrub radius phenomena.
Best racing teams are vary of ill effects of their suspension alteration, but tradeoff can well be worth it - car will lap faster times around a track. These fine tuned changes do however change from one racing track to another.
