3rd gen 3sgte - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 06-27-2006, 12:00 PM   #1 (permalink)
MAX BOOST!!!!!!!
View mr2_dori's Photo Gallery
2nd Generation 3rd gen 3sgte
i was told that the 3rd gen has 13psi stock boost, then 18 psi with fuel cut. well mine is running 8psi. i was told that my t-vsv is holding me back. do 3rd gens had t-vsv. turbo-vacum switch valve?
mr2_dori is offline   Reply With Quote
Old 06-29-2006, 10:16 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $301775
Yes, there is two different boost levels that a stock 3rd gen 3s-gte runs at. If you are only getting 8lbs, it may just be because the ECU isn't happy... when conditions are right, it will boost up around 13lbs. (via the T-VSV, like you said)
-Charlie
Old 06-30-2006, 09:48 AM   #3 (permalink)
MAX BOOST!!!!!!!
2nd Generation
what about octane levels. someone told me that since the fuel in japan are highr the boost if at 13. here we have 91. so the ecu is holding me back on 8psi. i just ordered 109 octane to try to see if that works.
Old 06-30-2006, 01:11 PM   #4 (permalink)
white90dx's Avatar
The octane of gas is rated somewhat differently in Japan than in the US. Their top octane level (98 or 100 or whatever) is approximately equivalent to 94-95 octane in the states. Many people have been successful running up to 17psi on stock 3rd gen motors with gas as low as 91 octane (california).
Gas is most likely not something that is holding you back. Its probably some other sensor...
-Charlie
Old 07-09-2006, 06:31 PM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
see if the exhaust is plugged up?
Old 08-22-2006, 06:33 PM   #6 (permalink)
View diengcamry's Photo Gallery
Any of these symptoms?
http://www.mrcontrols.com/primers/fuelCut.htm
diengcamry is offline   Reply With Quote
Old 09-26-2006, 09:00 AM   #7 (permalink)
View Stay Tuned...'s Photo Gallery
as far as i remember there is no Tvsv or tvis crap on the JDM mr2 and def not on the third gen . 13 spi sound right. check all your hoses, timing, exhaust for restrictions...and check to see if your turbo is spinning freely, check knock sensor.
Stay Tuned... is offline   Reply With Quote
Lack of power - gen 4.5 v. gen 3 skewe 3rd & 4th Generation (1992–1996 & 1997–2001) 43 07-11-2007 11:40 AM
3rd gen 3sgte in a 5th gen celica toyotaspic Celica Forum 2 02-10-2007 01:54 PM
how can you tell what gen 3sgte you have? TRD3sgte MR2 Forum 2 12-04-2003 10:37 PM
