Brake Question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 07-15-2006, 03:58 AM   #1 (permalink)
View Zvolen's Photo Gallery
Brake Question
I am out of ideas, I was helping a friend replace his disc brakes in a 95 Chevy S-10 and after completing everything and bleeding the lines we start the car and have no pressure at the pedal, no matter how many times he bleed the brakes same rsult. Also, the emergency brake light won't go off any help would be greatly appreciated, or any question feel free.
Zvolen is offline   Reply With Quote
Old 07-17-2006, 12:45 AM   #2 (permalink)
View toyomoho's Photo Gallery
Was the brake pedal firm before the brake job? Did the pedal ever firm up after bleeding the brakes. Power assist brakes will magnify any softness in the brake pedal. Are you sure you got all of the air out, and did not allow air to get into the master cylinder when bleeding the brakes? You can try clamping off the front brake lines then seeing if you get a firm pedal. Use something with a wide contact area so you don’t permanently pinch or damage the lines. Could be a bad master cylinder. Remove the clamps one at a time to determine if the front left or right brake is causing the problem. Any brake fluid leaks?
The emergency brake has a switch on the ratchet mechanism somewhere. This switch can get stuck on, misadjusted, etc.
Old 07-29-2006, 01:53 AM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395160
iTrader Score: 13 reviews
first off, it sounds like you guys probably bled the brakes wrong.
make sure that when the person takes their foot OFF the pedal, the valves ae closed, otherwise the system will suck air back in, and the brake fluid will froth and bubble with air meaning no brake pressure at all almost. the first time that I bled my brakes, I made this mistake and didn't realized it until I had put all my wheels back on
and the emergency brake light means not enough brake fluid- that's how toyota designed the warning light
HaHa
Brake question dave_thomas Camry & Solara Lounge 12 08-10-2004 09:29 AM
Brake Rotor question techguy Camry & Solara Lounge 5 07-26-2004 11:12 PM
Question about Brake Bleeder valve.. GrantTPC Camry & Solara Lounge 7 09-14-2003 11:04 AM
Brake Question rpj1984 Hardcore Tech and Competition 3 09-03-2003 01:34 AM
Brake question. REN69 General Discussion 8 06-17-2003 10:07 PM
