Electrical problems
Hello all:
I have a 2002 Toyota Celica GTS.
Here is my problems, or should I say problems.
My DRL, fuel guage, auto door locks (or anything to do with the door, including the dome light, door open warning light, key in ignition warning, etc....) and rear hatch lock doesn't work.
Here is what happened. I got into a rear fender bender. Not bad. Car hit my left rear side. A month after the car was repaired, I started the car and noticed that the gas guage wasn't working. I kinda freaked out because at that time, people were stealing gas from cars. I thought I was a victim. But, I wasn't, my gas tank was full.
I noticed that other things (mentioned above) weren't working.
I checked all the fuses (all good). I checked the connections (all good). I kinda figured that the problems were connected to the B7 and/or B6 wiring (from the manual). But, I cannot figure out what the hell is wrong.
Any ideas? Do you think it could be the ECU? Or something related to the accident (wiring or some electrical component in the rear where the accident happen)? Grounding problems? something?
My last resort is to take it to the stealership to figure out the problem.
Thanks ahead for any advice.
