how much does it weigh ? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 08-16-2006, 09:16 AM   #1 (permalink)
Banned
View bbsgarage's Photo Gallery
AE86 how much does it weigh ?
Looking for the typical weights of an ae86 model corolla.
Thanks.
bbsgarage is offline   Reply With Quote
Old 08-16-2006, 09:17 PM   #2 (permalink)
crazy wheels
mr2driver's Avatar
View mr2driver's Photo Gallery
isnt around 2200?
mr2driver is offline   Reply With Quote
Old 08-19-2006, 10:13 AM   #3 (permalink)
Banned
Thanks for the reply,
But I am a little dissapointed though, 65,000+ members and the best I can get is a guess.
No one knows the weight of a gts or other similar ae86 corolla?
Old 08-19-2006, 10:25 AM   #4 (permalink)
crazy wheels
mr2driver's Avatar
put this in the corrolla section and you will get more replys
i can get the exact weight from certain sites but i dont know how accurate it is. basically its just rounded give or take a hundred
Old 08-19-2006, 01:14 PM   #5 (permalink)
Banned
Thanks, I gues I just expected more from the "hardcore" tech section
Old 08-19-2006, 03:22 PM   #6 (permalink)
519
Custom User Title
519's Avatar
View 519's Photo Gallery
SR5 and GTS
Weight: approximately 2200 lb (998 kg) to 2400 lb
'99 Corolla VE
*If you're having car problems, I feel bad for you son...*
*I got 99 Problems but my toy ain't one.*
519 is offline   Reply With Quote
Old 08-19-2006, 05:31 PM   #7 (permalink)
Gameroom cash: $102420
View 90celica's Photo Gallery
each feature + or - changes the weight!
1990 Celica GT - work in progress
1994 Tercel
90celica is offline   Reply With Quote
Old 08-19-2006, 06:37 PM   #8 (permalink)
Banned
How easy or hard would it be to get one to a race weight of about 1600 lbs ??
Old 08-20-2006, 10:38 AM   #9 (permalink)
i would say impossible!
1994 Tercel
Old 08-21-2006, 09:23 AM   #10 (permalink)
Banned
So there isnt 600 lbs to loose?
Removing the interior, bumpers, light weight drivers seat, fibreglass hoods, fenders, replace the glass, pull any AC, PS, sound deadening matls etc.
How close to 1600 lbs if not?
Old 08-21-2006, 07:17 PM   #11 (permalink)
crazy wheels
mr2driver's Avatar
600lbs is a lot to lose. you could get it down to 1800 im sure but 1600 idk
Old 08-21-2006, 10:24 PM   #12 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
Typically people say they weigh around 2300 lbs. Thats a general weight though so when you take things like power steering/windows/locks out you will loose a little
I would say on the US models the bumper rebar would be a good way to lose weight, you could use the JDM bumpers which weigh less but aren't cheap. Seat are another heavy item, not so much your rear ones as they are mostly foam. Gts seats on the ae86 and ae92 aren't very light because of the adjustments they have, buckets will save you a bit there also.
600 lbs though is ALOT. But remember not to make it to light or to offset the balance to much as it isn't a race car. Your looking at changing panels to carbon fiber and fiberglass, replacing the glass with plastic make the doors part of the body so you can remove things like handles and the mechanism inside the door. Even then it may not be enough to get it to 1600.
**edit**
another thing, avoid a sunroof if you haven't bought the car yet, as even if you remove it the undeside of the roof has a pocket to hold the panel for it to roll back which will add a decent weight (I figure it's obvious but won't hurt to say it)
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 09-25-2006, 07:29 PM   #13 (permalink)
View kevlar corolla's Photo Gallery
My race only AE86 weighs 1715lbs,it's pretty hard to get to that weight.Car is currently competely stripped inside with only a drivers seat,4 gallon fuel cell and a 6 point cage.The doors are kevlar as is the rear hatch and a 1pc lift off front end,I built all the moulds and parts myself.The rear quarters and roof are next,should drop a few pounds as I will cut all metal off from the top of the windsheild down to the bottom of the rear glass.
All bumpers and supports are removed as well,no ps etc etc either.I have a rather heavy engine being that I've supercharged a 20v.With the roof/rear quarters removed and replaced with the kevlar pieces and going back to an NA engine combo I would very easily be in the low 1600lb range.
If you want one this light be prepared to spend lots of cash,do lots of work and never ever be street legal again.
kevlar corolla is offline   Reply With Quote
What do the stock prerunner wheels weigh? Royalchoppers 2nd Generation (2005+) 3 05-23-2006 11:59 PM
how much does the 2nd gen camry weigh? 90celica Camry & Solara Lounge 1 05-13-2006 02:00 AM
What do OEM wheels usually weigh? Mosquito Camry & Solara Lounge 2 11-29-2004 08:50 PM
How much do 3sfe/5sfe flywheels weigh? Talisman 3rd & 4th Generation (1992–1996 & 1997–2001) 10 06-20-2004 02:52 AM
Ever wonder how much your wheels weigh? Phi Hardcore Tech and Competition 3 03-28-2003 01:02 PM
