Oil Pressure a little low from installing Omori oil filter relocator. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 08-31-2006, 11:29 AM   #1 (permalink)
View JoeJITSU's Photo Gallery
My oil pressure got a little lower from the install. Anybody have the same problems? thanks
JoeJITSU is offline   Reply With Quote
Old 10-19-2006, 12:18 PM   #2 (permalink)
Here To Learn And Help :)
View SequenceGarage's Photo Gallery
How much lower?
Its normal for oil pressure to be slightly lower when you add anything to the system, but if it is drastically lower then you most likely have a leak. Check for fittings with oil on them, even if oil isn't dripping if they are moist they most likely have a leak that is most likely only evident at high oil pressure (high rpm) and high oil temp. Good luck
Sasha Anis
Founder Of Sequence-Garage
Here To Help And Learn
SequenceGarage is offline   Reply With Quote
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
5s-fe turbo install list R94CamryT Hardcore Tech and Competition 32 04-29-2009 01:37 AM
30,000miles on single oil change(how to help my car?) Part 2 Rob-D Camry & Solara Lounge 6 10-14-2006 12:26 AM
Full synthetic motor oil - 32˘ /quart + 1 oil filter ... Pep Boys skewe General Discussion 7 01-19-2006 03:31 PM
