Question about install of new Distributor Cap & Wires - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 09-11-2006, 12:51 PM   #1 (permalink)
elka's Avatar
View elka's Photo Gallery
Question Question about install of new Distributor Cap & Wires
Sorry if this is in the wrong forum, I wasn't sure if I should post it here or not. Here's my question:
Engine and car: 1990 Toyota Camry 4-cyl 3SFE engine 2.0L
Parts used: Borg Warner Sure Spark wire and cap set.
I have done other repairs on my cars before but this is my first Toyota and first time replacing a ditributor cap and wires.
I replaced my distributor cap, wires and spark plugs this weekend. I made a big no-no and did not note the order of the wires on the old distributor cap. *oops*, only because I had assumed that the numbers on the connectors of the new distributor cap would correspond with the numbers of the cylinder it should lead to, am I right?
For example I just connected the number #1 on the Distributor cap to the #1 cylinder. Then #2 on the cap to the #2 cylinder, etc. It started up just fine. However....
When I looked at this diagram of firing order I panicked and thought I should follow this instead:
http://z.about.com/d/autorepair/1/0/j/h/41763334.gif
but then it wouldn't start. So I wired back by number on cap to number of cylinder again and it started right up. Should I be worried about this or did I do it right by corresponding the numbers on cap to the number of the cylinder?
Thanks in advance,
Elka
elka is offline   Reply With Quote
Old 09-11-2006, 01:25 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
That diagram is wrong.
If your looking at the distributor cap:
#1 = bottom left.
#3 = bottom right.
#4 = top right.
#2 = top left.
I don't know about the Borg Warner cap and wire set, but with OEM (Toyota, Denso) the wires are a certain length. So its hard to get the wires in the wrong spot.
"Skoolin' the unlearned!"
Old 09-11-2006, 01:29 PM   #3 (permalink)
elka's Avatar
I figured as much.... The diagram is what threw me off track, so it should be all kosher now yeah? Thanks for the advice, I thought I was right the first time but sometimes I need to hear it from an experienced person to make sure.
Old 09-11-2006, 02:06 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
Yup.
As long as it runs and theres no misfires.
SSauto Intercooler install.... Mr2SlOw... MR2 Forum 11 02-19-2006 02:29 PM
Cusco 2-way LSD install Question (ae86) sunsmoker Archived Corolla threads 1 10-19-2005 07:48 PM
-PICS- TOY03-AUX install & Wiring Color Question mmessier2 2nd Generation (2005+) 11 10-15-2005 03:50 PM
Quick question about stereo install Fuzion Audio, Video, and Security - Tech 7 08-10-2004 10:39 PM
