downshifting into 1st gear problems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 04-26-2003, 02:01 PM   #1 (permalink)
View wontonjohnny's Photo Gallery
ive noticed on most older cars its difficult to downshift into 1st gear.... can this be fixed ???
anyone know how to fix this problem??
5 speed 3vzfe - RIP
project F23 CL-T
Custom Y-pipe Project
Custom 1-Piece CAI Project
wontonjohnny is offline   Reply With Quote
Old 04-26-2003, 02:19 PM   #2 (permalink)
View Naito's Photo Gallery
double-clutch into it.
Naito is offline   Reply With Quote
Old 04-26-2003, 02:23 PM   #3 (permalink)
yeah but new cars that i have driven dont require double clutching ...
i dont downshift much anyways... its more coming to a rolling stop at a stop or yeild and it wont go in until im like almost completely stopped.
5 speed 3vzfe - RIP
project F23 CL-T
Old 04-26-2003, 02:44 PM   #4 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
hmmm its supposed to be like that, 1st gears are usually gated,
you should never downshift into 1st, unless you're virtually stopped
oh and if you're coasting, please save your clutch bearing, don't leave the pedal down
-Nick
Nick is offline   Reply With Quote
Old 04-26-2003, 02:52 PM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $270021
View REN69's Photo Gallery
Rev matching. Before you go down to 1st gear, step on the gas once to rev the motor up, then stick into 1st right after. This way you won't get the motor-brake effect that you usually get when you downshift.
Make sure you're not going too fast though.. first gear isn't really supposed to be downshifted, because if you're going too fast.. you could blow your engine. 10-20km/h plus a revmatch should be ok.
Old 04-26-2003, 04:18 PM   #6 (permalink)
even with synced trannys, you still can help relieve some stress on the synchros by double-clutching. You don't need to for the higher gears because the ratios are close enough, 1st is usually much wider than other gears, so if you wnat to shift into it while moving, it helps to give the synchros a hand by double-clutching.
Old 04-26-2003, 10:35 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Could be your syncro is worned out.
Old 04-27-2003, 01:26 AM   #8 (permalink)
The terrorist
View Xenon's Photo Gallery
Why would you need to down-shift to 1st gear in the first place, the lowest gear you should down-shift to while the car is in motion is 2nd gear!!
You only need to put the car in 1st if you're stopped, or you're traveling at speeds less than 20Km/h!
My sexy AE92 http://members.cardomain.com/ababan
Xenon is offline   Reply With Quote
Old 04-27-2003, 05:34 AM   #9 (permalink)
Resident asshole
Flashmn's Avatar
I can pop into 1st gear easily its good for acceleration from a very slow speed also.
Old 04-27-2003, 01:13 PM   #10 (permalink)
i think you might of missed my previous post ...read my second one
5 speed 3vzfe - RIP
project F23 CL-T
Old 04-27-2003, 01:25 PM   #11 (permalink)
View 1owner's Photo Gallery
If the revs are right and the speed is right and you're not trying to accelerate or decelerate while switching, it should just snick right in. If not, you probably shouldn't be trying to force it into 1st anyway. In stop and go on the 401 sometimes you just have to go there. Double clutching works for me.
Be kind to your syncros.
'89 Corolla GT-S (RIP 1989 - 2003 very sad!)
'67 Chevelle (2owner)
'10 Passat (1owner)
'84 Honda XL350R (1owner)
All mint!
1owner is offline   Reply With Quote
Old 04-27-2003, 03:39 PM   #12 (permalink)
In Ur MOM's Pants
RedruM's Avatar
View RedruM's Photo Gallery
like Xenon said you shouldn't even need to down shift into 1st
but dont forget our older cars do have a factor of wear and tear on them no matter how well you maintain .... where as new cars, well they new so them can handle some abusive 1st gear downshifting
keep the signatures clean please
RedruM is offline   Reply With Quote
Old 04-27-2003, 11:20 PM   #13 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
I tried downshifting during a run around the track and I swear my tranny climbed out of the hood and gave me a dirty look.
Problem I have with second to first is there are times, such as coasting to a stop light which suddenly turns green, where second bogs you down but you're too fast for first. In that situation I end up having to rev to like 4 grand before it'll let me into first. I guess really it's just poor gearing for that sort of situation.
-- Jonathan W.
http://fleshy.org.nz/
brink is offline   Reply With Quote
