I hope someone can offer some insight into a problem with my 2001 Corolla.
Over a year ago my local car club got a group rate to do dyno runs. I decided to take my Corolla (only mod CAI) over for a baseline run. Stock 2000-2002 5-speed Corollas generally put down about 110 hp and 110 lb-feet of Tq to the wheels. Mine dynoed at 88 HP and 98 lb-feet of Tq. The techs were afraid to do a third run because my A/F ratio was “dangerously lean” up to almost 17 around 6,000 RPMs. The obvious reason for the low power was the lack of fuel. I had no check engine light at the time.
A few months later I got a check engine light, but it was “rich condition cylinder #1” which was solved by ditching my CAI, which had a muddy, clogged filter.
Later on during this year, my clutch started slipping badly, and I am now having it replaced. I haven’t driven the car yet with the new clutch, but I noticed a lack of power at high RPMs before the clutch was slipping.
If I put 87 octane in the car, which it is supposed to run on, it knocks a little. It seams to run better on 89 octane, but still lacks high-end power.
I asked the guys that are doing my clutch to put the car on their engine analyzer, but they said they can only reference trouble codes and there is nothing to check if it isn’t throwing a code.
Questions:
How can my A/F be so bad without throwing a check engine light?
Is it possible that the Wide band O2 sensor could have been thrown off by a slipping clutch (to my understanding it is independent and does not reference the dyno output, plus I do hear knock with regular fuel)
What could be causing the lean condition if one exists? (I checked the O2 sensor voltage and it was working right if I checked it right, I cleaned my MAF as well.)
My last idea is to pull the fuel pump and see if the inlet screen is clogged up.
Answers/guesses/thoughts appreciated.
-Chris
