.......... Help .......... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 10-16-2006, 12:54 PM   #1 (permalink)
View heatwavewo's Photo Gallery
just got my brake serviced and tire rotation done on sat (tires balanced as well), after that i drove highway home on that night, and i noticed the steering was off to the left a little, and when i drive 100km+ the steering wheel start to sake, so first i thougth it was just the alignment, on sunday i took the car to active gree+ross to have alignment done, but after that the steering is still off to the left a little bit and sakes when over 100km+.
on monday i took the car back to the shop where i had it brake serviced and tire rotation done, they balanced the tires and everything was fine, so i took a test drive but STILL SAME PROBLEMS, back to the shop, we rotated the tires back to where it was, front to the back and balanced, then i took off and head to work, while i was on the highway the steering is STILL off to the left a little, and when i do over 100km+ sitll shakes a little ( little better then before ) but still...
.............................. HELP ....................................
heatwavewo is offline   Reply With Quote
Old 10-21-2006, 01:42 AM   #2 (permalink)
thousand_five's Avatar
View thousand_five's Photo Gallery
are your tires evenly worn? My car shakes a little too right now, but that's because I laid down some tread a week ago and I have deep flat spots on my tires.
1993 Celica ST-------------- Successfully swapped A 5afe 1.5L works great!
1992 Celica ST-------------- Daily Driver 236,000 miles currently
1991 Celica Convertible---- Father's daily driver
thousand_five is offline   Reply With Quote
Old 10-23-2006, 09:32 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
sounds like you have a bad tire, try swapping the fronts side to side and see if it pulls the other way, if not the toe is off, go real slow in a parking lot and see if one end of your car wabbles
Old 10-24-2006, 05:17 PM   #4 (permalink)
View Electric Pi's Photo Gallery
You did not say what kind of vehicle you drive. Toyota has been known to use lug-centric wheels on some trucks. These wheels cannot be balanced correctly using a standard wheel/tire balancing machine unless an adapter is used.
Rally = Real cars, on real roads, going real fast.
http://www.youtube.com/ElectricPi
Originally Posted by rice
how do you guys tell if a car is AWD??
Electric Pi is offline   Reply With Quote
