could get a thermostat that's set a bit lower, could get another fan, another rad, could make sure your fluid is good and new
but what you could to to increase airflow into the engine bay, is to take off your hood, and put a couple of washers between the hood and the bracket, lifting up the rear of the hood, lets air exit better, even creates a suction, lots of sports cars have what look like reversed ram air scoops, this is their function
What about your rad, are all the cells safe in there? Is it missing a lot of cells!, check the pressure on the big tube runnung from the top of your rad to you engine and see if it's stiff or sqeezable!
My sexy AE92 http://members.cardomain.com/ababan
Originally posted by Xenon What about your rad, are all the cells safe in there? Is it missing a lot of cells!, check the pressure on the big tube runnung from the top of your rad to you engine and see if it's stiff or sqeezable!
well after the head gasket blew in my car, my mechanic assured that its still driveable.
but yeah, all the tubes are in good shape.......no cracks, leaks or stretching.
I dont bite styles, but I do bite nipples, if she is freaky.
Flushing the rad is very simple, but you should do a proper flush at a mechanic or a certified place, they use a mechine to circulate a cleaning fluid through your system and it's clean all the pipes and parts associated with the cooling system..
That usually costs about $60
