Tranny Cooler *pics* - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 05-25-2003, 05:48 PM   #1 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
I had my tranny cooler installed a few weeks ago and decided to snap a few shots and share with ya'll. The quality of the pics are kinda crappy though.
It was installed by T-Lex with mounting brackets instead of the zip-ties supplied by the manufacturer. This was done to create a gap for air to circulate all around the unit.
I got the cooler from a local dealer for CAD$80. It's a Tru-Cool made by a company called Long/Dana and I've been told by Ekam that it's identical to the B&M one. The dimensions are 7 1/4 x 11 x 3/4 with a 18,000 gross vehicle weight rating and 13,000 BTU rating. It also uses Low Pressure Drop technology. Visit their website for more info (here) <-- The server isn't always functional
In addition, I also flushed the tranny and refilled with Redline High Temp ATF.
http://www.imagestation.com/album/?id=4290081899
Phi is offline   Reply With Quote
Old 05-25-2003, 07:38 PM   #2 (permalink)
The terrorist
View Xenon's Photo Gallery
I heard a lot about these tranny coolers and how they double your transmissions life. What I would like to know is were does the fluid go and how does it get cooled? How is the cooler connected to the tranny?
My sexy AE92 http://members.cardomain.com/ababan
Xenon is offline   Reply With Quote
Old 05-25-2003, 07:51 PM   #3 (permalink)
Boro Box Pilot
boroEF's Avatar
View boroEF's Photo Gallery
Re: Tranny Cooler *pics*
Originally posted by Phi
(there were) zip-ties supplied by the manufacturer.
whoa i like the sounds of that why did u use mounting brackets instead
The boro guru
geocities.com/nuahs_cx my site about ae92, ef and track info
boro song
"boro boro boro
here we have a duct tape la la la
here we have an electrical tape du du du
here we have a coke can da da da
and then we have a downpipe!! boro boro boro"
boroEF is offline   Reply With Quote
Old 05-25-2003, 08:01 PM   #4 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
The oil cooler is connected in series with the radiator.
(Tranny)---fluid---> [radiator]--->{Cooler}--->(Tranny)
The cooler is just like a mini rad which circulates the fluid through numerous channels.
First off, the zip-ties are flimsy and I doubt they'd last long. Secondly, mounting using the brackets allows me to keep it off the rad and leave a gap for air.
Old 05-25-2003, 08:08 PM   #5 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
How much was installtion? Less than $150 to double your clutch's life sounds good to me.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 05-25-2003, 08:09 PM   #6 (permalink)
Boro Box Pilot
boroEF's Avatar
^first off, i was kidding.
secondly, u are rich nice new mod
The boro guru
boro song
"boro boro boro
Old 05-26-2003, 08:55 AM   #7 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
way to go Phi looks just like my B&M, which was suprisingly $80 as well... (do you smell conspiracy?)
anyways... tranny coolers should be mandatory for every A/T vehicle... especially a FI car like yours.
ratko.org
Ratko is offline   Reply With Quote
Old 05-26-2003, 03:25 PM   #8 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
propper installation is tranny, cooler, rad, tranny, that way you maintain proper operating temperature, especially important in winter
now on the track where you're always pushing it might be better the way you have it set up, but for everyday the way above is much better
-Nick
Nick is offline   Reply With Quote
Old 05-26-2003, 04:39 PM   #9 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
^ I totally agree with you and was debating the issue myself. I figured, I don't drive my car that often in the winter, especially not during frigid tempuratures. If I did, I'd just let the car warm up alittle longer. Secondly, the way the cooler is designed, it directs the thicker, cold fluid to flow through the top rails. As it gets hotter and thinner the fluid is allowed to flow through the entire cooler. This design reduces the possability of dangerous pressure drops.
Thirdly, by-passing the stock cooler and going to the cooler first would void the warranty (not that my warantee is in tact )
Stealth: shouldn't be more than 0.5-1hr labour
Old 05-26-2003, 05:04 PM   #10 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
I just re-read the PDF file briefly describing the cooler and the installation details. They describe installing the cooler "in series and downstream of the in-tank radiator oil cooler"
So does downstream mean before or after the rad? I inturpret is as being after the rad. ( I are a FOB and do bad engrish :o )
Old 05-26-2003, 05:14 PM   #11 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
So does downstream mean before or after the rad? I inturpret is as being after the rad. ( I are a FOB and do bad engrish :o ) [/B]
After.
"Skoolin' the unlearned!"
Old 05-26-2003, 05:59 PM   #12 (permalink)
Nick's Avatar
that's interesting, well i'm sticking to my story, after all it is straight from an old grey volvo rally mechanic
-Nick
