double-clutch and clutch wear - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 12-06-2006, 06:53 AM   #1 (permalink)
View grosbucheron's Photo Gallery
When downshifting, I always double-clutch (and, if braking, I go for heel-toe braking) and I was wondering if it had anything to do with the premature wear of clutch components.
Last spring I had my 05 Echos' clutch bering replaced because it was sliping on highway acceleration.
It did it again, hence my dealer replaced (under garantee) the whole thing -- clutch, pressure plate and bearing-- no later than yesterday.
Should I *not* double clutch? Hope this is not the problem : gears go in much easier this way!
I did pull a Vermont forest ranger's Ford Explorer out of the ditch last winter , but that was before the first bearing replacement : I do not think it should explain the problem coming back.
grosbucheron is offline   Reply With Quote
Old 12-06-2006, 11:25 PM   #2 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
You're not driving a 1930's truck, you've got a synchronized modern transmission. Double clutch and you're using the clutch 2x as much, of course its going to wear faster.
foot off gas, clutch to the floor, pull down/push up, release clutch, resume gas. Clutch last long time.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 12-07-2006, 12:28 AM   #3 (permalink)
PICKLE GANGSTER
Rdizzle's Avatar
iTrader Score: 6 reviews
View Rdizzle's Photo Gallery
^exactly. We have syncromesh stuff. No double clutching in this day and age.
Originally Posted by DarkMastyr View Post
Is it just me, or has TN just become this massive gay fest? It's like you can't avoid the hot gayness in every thread.
[U]
http://www.cardomain.com/ride/398065...ry-le-coupe-2d
Rdizzle is offline   Reply With Quote
Old 01-19-2007, 10:22 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $549725
I have a question along the same lines.
When down shifting sometimes, I'll hold the throttle down, clutch in, RPMs surge slightly, down shift, and let the clutch go. When I get this right, the engine RPM will surge to within about 100-200 RPMs of the input on the transmission.
Another thing I do sometimes is clutch in, shift while blipping the throttle, and then releasing the clutch.
How does down shifting this way affect wear of the clutch. My understanding is that when the clutch pushed in all the way, the engine is seperated from the transmission so it should be ok right?
2007 Camry 2.4L 5M
Old 01-19-2007, 11:23 PM   #5 (permalink)
ASE Master, now Realtor
timebuilder's Avatar
View timebuilder's Photo Gallery
Whenever the clutch is in the process of being engaged or disengaged, the disc, pressure plate, and throwout bearing are giving up a little bit of their lifespan.
Holding the clutch in does separate the engine and transmission, but the throwout bearing is spinning under load the entire time the clutch is held in, pedal to the floor. When the clutch completes its engagement, pedal up, there is virtually no wear unless the torque created by the engine exceeds the ability of the pressure plate to maintain a lockup with the clutch disc. If the pressure plate and flywheel cannot keep the disc locked between them due to excess torque, the clutch will have its greatest wear while the disc slips. Continued slippage leads to mechanical failure.
If you spend any time with a large truck, you may double clutch by force of habit.
Courage...Honor...Conquer
timebuilder is offline   Reply With Quote
Old 01-22-2007, 11:13 PM   #6 (permalink)
View Grayguy's Photo Gallery
Or you might want to double clutch if your synchros are going bye-bye. Hell once your moving, why bother using the clutch. Much smoother without it.
Grayguy is offline   Reply With Quote
Old 04-06-2007, 08:59 PM   #7 (permalink)
BackYard Engineering
Evo_lucian's Avatar
Gameroom cash: $102535
View Evo_lucian's Photo Gallery
Thanks guys i learnt alot through reading this thread. Now i know why my clutch only lasted 4 months on my levin.
Evo_lucian is offline   Reply With Quote
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
UPDATE: Clutch problem canadianae92 Archived Corolla threads 2 10-29-2005 05:13 PM
My clutch has started slipping and I dont know why REAPER STRAIN Camry & Solara Lounge 55 09-19-2005 07:47 AM
new clutch = broken wallet eyz closd MR2 Forum 4 03-12-2005 04:16 PM
