Originally posted by Deep
Whats the deal with your propane burning 4AG?
You mean why?
My 84 Celica was quite well 'used' - I have a heavy foot and Toyota's are one of two types of cars that I don't break, the other was a '76 Alfetta (that's another story.)
Looked in the paper and saw a modded AE92 for sale. I love the styling of the GTS. I bought it. I found out the hard way that the person who did the mods didn't do a sound job and after only a short time I broke a piston.
I rebuilt the engine, made new alternator mounts (you have to move it underneath to fit the MR2 SC on and the guy who did it before me flippin had it on crooked so the belts only lasted a month or two. Remounted the pump fer the intercooler ... etc etc. I was lucky however because the scoring was minimal and most of it came off with only a tiny bit of honing.
Not wanting to repeat and loving the acceleration I had before it broke. I decided to park it until I had a fix. I used to know the Owner of sdsefi.com and had seen what he had done with forced induction so I first I looked into programmable ECU's /w water injection and larger injectors. About $2200. I don't have an extra $2200.
What made me look to propane as an alternative. Two words ...
My dad.
The man is a retired maintenance supervisor of about 5 HD mechanics 2 LD mechanics 12 millwrights and countless electricians, is a mechanical genius. He had all the fleet vehicles (mostly 6 cylinder chev pickups) at his work converted about 20 years ago and all the engines lasted at least 1.5 to 2 times longer. He has also built several high powered V8's for his own use with 11.5: compression and all the other cool V8 stuff (list is too long and I am a lousy typer
(two 454 chevs and a -- dodge 440 -- about 500 HP and 600 ft lbs of torque. fastest maxivan you ever saw lol )
He suggested I look into it.
I did.
This was my conclusion.
Gas price in Calgary .. usually at or above 65 cents / litre.
Propane can be found for 45 cents or less.
Price of ECU/Injectors ignition system, anti knock device, water injection with gas $2200 Canadian or more.
Price of Propane gas tank propane lines lock off converter and mixer $1000 dollars.
Note: I now have everything but the tank I got it for $150. that is right one hundred fifty. Used of course but who cares.
If the conversion is approved I may be eligible for a $400 grant.
Pump gas octane 92
Automotive Propane Octane rating 104
Evaporative Emissions from a gas engine well .. suck
The evaporative emissions from an LPG system are well .. none they are a closed system.
Operating emissions from a gasoline engine include sulfur, carbon monoxide, well the list goes on.
Operating emissions from propane, well gee 'almost' entirely CO2 and H2O extremely low levels of CO in comparison and some Nitrates. (this is why one can use propane on indoor vehicles like forklifts and not gasoline.
HP with supercharger and stock pistons on street gas before fatal detonation occurs --- I blew a piston proving this BTW ... 150-160
Estimated HP on propane with supercharger and stock pistons before fatal detonation occurs 190 although I may govern the car to 160ish to save the drive line.
Propane engines require less maintenance.
When filled to capacity Propane fuel tanks weigh less than a comparatively sized gasoline tank.
Propane fuel tanks are rated 54% safer than gasoline tanks by Liberty Mutual insurance company.
No one can 'siphon' my gas.
Soon, everyone will do as I am doing. Forced induction and propane are made for each other. NG is even better but the equipment is more expensive.
chant with me now ....
C2H8 IS GREAT C3H8 IS GREAT ...
Rezzle.
