valve guide replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 06-05-2003, 02:18 AM   #1 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
i believe my valve guides are toast, so how about changing them? i'm probably due for a head gasket replacement as well so 2 birds one stone
is it possible to change these out? need special tools? how about putting them back in? must need some sort of way to hold them in there
-Nick
Nick is offline   Reply With Quote
Old 06-05-2003, 03:03 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: valve guide replacement
I suggest that you take it to a machine shop, engine builder, or a place that works on cylinder heads.
The valve guides are not something you can replace yourself unless you know what your doing.
"Skoolin' the unlearned!"
Old 06-09-2003, 10:18 AM   #3 (permalink)
View 2drcam's Photo Gallery
yeah 88 le is right.
first the guides have to be machined out then the new ones have to be pressed in (very precise)
2drcam is offline   Reply With Quote
Old 08-04-2003, 05:38 PM   #4 (permalink)
View Richard's Photo Gallery
Cool Valve guide replacement
Changing valve guides need special tools for removal and replacement also you will have to ream the new guides once they have been installed. I replace the guides on every head we build for competition.
Your clearance should be no more than 0.001" max. between guide and valve. 0.00025 and 0.0005 is ideal.
Regards Richard (TED)
Richard
Kamakazee Kid
Keys to the kingdom in my head;
Cylinder head that is..................
Richard is offline   Reply With Quote
Old 08-04-2003, 09:44 PM   #5 (permalink)
Nick's Avatar
dead thread revival, yeah, don't care anymore, i jsut let her burn oil
-Nick
Old 08-05-2003, 04:38 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
I think you meant valve seals instead of valve guides.
If your going to pull the head / heads off the only special tool you need is a overhead valve spring compressor.
