What exactly are you asking...if there's any surprises taking out the fuel sending unit assembly? If so, it is really simple. I just did this on a gen 3...Take the back seat out by grapping it underneath and lifting up rather sharply to get it out of the mounts. Take the cover plate off with a screw driver. Disconnect the electrical connector, fuel supply and the return lines. Then using a nut driver, remove the bolts that hold the assembly to the tank.
If you're just replacing stock parts, reassemble and reinstall. When I pulled mine, I installed an aftermarket pump (Walbro high flow) that required a little custom work.
Hope this helps.
Steve
