gen3 Camry enginer stutters.....? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 06-18-2003, 08:57 PM   #1 (permalink)
A Poor College Student
The Wolf's Avatar
View The Wolf's Photo Gallery
I've got a problem with my 1994 Camry's i4 engine. When I'm slowing down, the engine will sometimes stutter and die; this is a random problem that doesn't occur often. It's only died twice. Suspecting the fuel system, my dad and I changed the fuel filter. Didn't help. This seems more likely to occur when I drive the car hard; say, reving above 4000 rpms for a few minutes from stops. I've called several local garages and was told that it couldn't be the injectors (as I first suspected), because the problem would occur all the time. After asking my brother, he said someone at his job had a similar problem on a 1993 and said it was the MAP sensor. I have also remove, checked, cleaned, and reinstalled all 4 spark plugs, as well as tested the plug wires. All is OK there. Any suggestions would be much appreciated... I believe that it could be the MAP sensor or possibly distrubtor, which I haven't checked.
The Wolf is offline   Reply With Quote
Old 06-18-2003, 09:56 PM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
i dont know about map sensor, but maf for my gen 3 was only 50 $ cad at the junk yard, so its not expensive to try out
what about the idle adjust thing? maybe clean that off
-Nick
Nick is offline   Reply With Quote
Old 06-20-2003, 06:43 AM   #3 (permalink)
View yrmac's Photo Gallery
Re: gen3 Camry enginer stutters.....?
Try cleaning your TB(Throttle Body) especially the butterfly mechanism, maybe its sticking and not giving the right air/fuel mix ratio.
FUNCTION OVER FORM
yrmac is offline   Reply With Quote
Old 07-15-2003, 05:10 PM   #4 (permalink)
The Wolf's Avatar
Alright, I finally took my Cam to the local Toyota dealer. I paid $74 for diagnostics, in which they found that I had a weak ignition coil. So I decided to let them fix it, as they already had my car and I was out of town. It was another $182 for the coil & labor. Final cost: $286, with a $10 environmental fee. Anyway, my car has stuttered twice since then, but each time I was able to rev up the engine and it stopped. That was about 2 weeks ago, so I still don't know what the problem is......
Old 07-15-2003, 10:23 PM   #5 (permalink)
Nick's Avatar
bring it back to the same place, tell them they missed something in their last diagnostic
fuel pump? does it do it at wide open throttle or just idle?
-Nick
Old 07-18-2003, 09:48 AM   #6 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
try ignition most likely the igniter coil inside of the distributor cap
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
