New here, with Avalon help needed - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 06-19-2003, 04:11 AM   #1 (permalink)
Zee
View Zee's Photo Gallery
Talking New here, with Avalon help needed
Thanks in advance for this forum. From just a quick read os some posts, I believe you folks will be as informative, helpful and friendly as my collegues over on the brickboard.com Volvo forum.
Here's where i need immediate help:
96 Avalon, Automatic, 70,000 miles OK oil change history on this 3.0L sludge-prone engine
Black coolant.
Looks black in the overflow bottle, thin watery red under the fill cap. Like diluted ATF.
ATF looks discolored, slightly dark as if it never has been changed.
No odor of either in each.
Am I correct in thinking the ATF is cooled through one or both of the side tanks of the coolant rediator? And that I probably have ATF leaking intoo my coolant?
Or, is there another way these fluids get mixed on this engine?
Also, is there a FAQ of technical issues where I could have studied up on such a question before posting (so as not to repeat frequently asked beginer's questions)
"Can't understand why people abort Volvos, either"
'03 Toyota Avalon, 40,000 '96 Toyota Avalon, 126,000 miles
'89 Volvo 740tic, 120,000 miles '86 Volvo 240DL, 220,000 miles
'95 Ford Contour, 125,000 miles '88 Ford Escort GT, SCCA ITB
Zee is offline   Reply With Quote
Old 06-19-2003, 04:22 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: New here, with Avalon help needed
Theres a tranny cooler built into the radiator. If you look at the bottom of the radiator you'll see 2 hoses that run to the tranny.
Toyota antifreeze / coolant is red. So what you think is diluted ATF is actually coolant.
"Skoolin' the unlearned!"
Old 06-19-2003, 04:26 AM   #3 (permalink)
Zee
Toyota coolant is red?
Oh, I forgot to ask is it was.
What is it? DEX-COOL? (I hope)
Old 06-19-2003, 04:40 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
Yup.
Its not Dex-Cool.
Its some special blend Toyota came up with. I know its silicate free though.
I would stick with the Toyota red coolant. It costs a little more, but its good stuff.
Ooops... Forget to add that i've used the Dex-Cool stuff in my 88 Camry before and it works fine. I used Prestone that comes in the silver bottle (coolant is orange), not the yellow bottle (green junk).
Old 06-19-2003, 05:20 AM   #5 (permalink)
Zee
about DEX-COOL
Ooops... Forget to add that i've used the Dex-Cool stuff in my 88 Camry before and it works fine. I used Prestone that comes in the silver bottle (coolant is orange), not the yellow bottle (green junk). [/B][/QUOTE]
I have been using the Texaco/Havoline brand (it is red) in all my acient Volvos. They converted to it without leaks. Just now getting a leaking rad on the '84, but that is with a used rad that has about 110K miles on it already.....
Because I have five cars, I may switch the Avalon to it, as well. Like to streamline & standardize maintenance services where I can.
Also I'll change coolant every two years unlike the previous owner who thinks this is a waste of money)
