4age megasquirt - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 02-13-2007, 11:50 PM   #1 (permalink)
View 86CRNR's Photo Gallery
4age megasquirt
Hi,
I'm trying to help a friend megasquirt a silvertop 20 valve motor. I was wondering if anyone could help me out with some conservative maps or maybe the Toyota CLT resistance values for megatherm?
86CRNR is offline   Reply With Quote
Old 02-14-2007, 12:06 AM   #2 (permalink)
Danno
View 89yotarollagts's Photo Gallery
im in the process of MS my ae92 as well... your best place to go is on the MS forums or CLub4ag if & when its back..
i cant help you with the maps, but i too needed the values for the CLT sensor so i emailed the guys i bought my MS from & they said to just use the default settings, (think its the GM default) said it was close & should work fine
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
89yotarollagts is offline   Reply With Quote
Old 02-14-2007, 12:33 AM   #3 (permalink)
What sort of signal does the 4age 20 valve distributor send?
Old 02-14-2007, 12:44 AM   #4 (permalink)
what about VVT?
Old 02-14-2007, 01:10 PM   #5 (permalink)
Danno
i am wiring to the 16v so honestly i am no help to you, i have never seen a 20v in person nor done the research to know anything that technical about it... like i said before you may want to try posting in the forums i mentioned... There you will have better luck
Old 03-17-2007, 07:43 PM   #6 (permalink)
Now with even more BOOST
View QuadCamSix's Photo Gallery
The toyota sensor is only like +10*F off from the GM sensor. I have used both on my build. I actually have the resistance values at work if you cant get it to work with the preconfigured GM temps.
As far as the VVT, im not too familiar with the 20V head but if it works like the other toyota engines you can use the MSextra code and drive the varicam solinoid directly via the target boost table. I know it sounds crazy to use the boost control feature as a VVT control but it should work as long as you set up the PWM correctly. In the worst case senario (if set up wrong) you get a high and low cam advance instead of a continuously variable cam.
MR2 V6 with an inordinate ammount of boost www.V6MR2.com
QuadCamSix is offline   Reply With Quote
Old 03-25-2007, 09:33 PM   #7 (permalink)
View AE86Sideways's Photo Gallery
Club4ag is back up and i believe there is a tech section on this. If not there are plenty of people in there that have done it.
AE86Sideways is offline   Reply With Quote
4AGE and 4AGE 20 valves for sale.. nixem311 Car Parts for Sale 11 08-26-2010 05:07 PM
supr injectors in 4age with 4age injector resistor box. Corollenertia Archived Corolla threads 0 07-08-2005 09:04 PM
