seeking technical input - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 06-25-2003, 05:02 PM   #1 (permalink)
Boro Box Pilot
boroEF's Avatar
View boroEF's Photo Gallery
so i compression tested my 4ag today thanks to shane...
results are as follows:
cyl1:215ish
cyl2:220ish
cyl3:100ish
cyl4:195ish
conclusion: obviously, cyl 3 is dead. but why is it losing that 100 psi and where is it going? to test if it was the rings, we put some oil in there and did the compression test again and it yeilded back similar numbers(reached 105psi).
so where could the compression be going? head gasket, valve seals?????? also...my oil is going somewhere. obviously, my bottom end is in tip top condition. i might just rebuild my head...but i'd like to know the culprit to this problem...
The boro guru
geocities.com/nuahs_cx my site about ae92, ef and track info
boro song
"boro boro boro
here we have a duct tape la la la
here we have an electrical tape du du du
here we have a coke can da da da
and then we have a downpipe!! boro boro boro"
boroEF is offline   Reply With Quote
Old 06-25-2003, 05:12 PM   #2 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
Im guessing headgasket since even cylinder #4 isnt showing full compression. I figure that there is a leak in the headgasket around the #3 and #4 cylinder. There is a chance however that you might have two bad piston rings or whatever...
ratko.org
Ratko is offline   Reply With Quote
Old 06-25-2003, 05:13 PM   #3 (permalink)
Boro Box Pilot
boroEF's Avatar
cant have bad rings....cos i put oil down cylinder 3 and did the test again...if the numbers rise then it means the rings...if they dont it means that rings are fine...my rings are good
i guess this will save me the hassle of an engine swap
The boro guru
boro song
"boro boro boro
Old 06-25-2003, 06:48 PM   #4 (permalink)
Druken Postwhore
TRDragoon's Avatar
View TRDragoon's Photo Gallery
told you ....the head gasket
leaky engine oil, white smoke outta exhaust, low compression.
but than again, it could be improper valve seating,and either way, you hafto take off the head off the block to check it anyways
soooooo when you starting?
The AE92 Master
UniQue_N_RaRe
TRDragoon is offline   Reply With Quote
Old 06-25-2003, 06:48 PM   #5 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
Cool! Get that shit taken care of and hello 3 digit whp!
Chris Corolla S is offline   Reply With Quote
Old 06-25-2003, 10:11 PM   #6 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
if everything itchy's saying is true, then its your head gasket, also (with a cold engine) open up the rad cap and look for bubbles (unless your thermostat is righ there)
its not that bad a job, plus you can clean off all the shit in your valves
-Nick
Nick is offline   Reply With Quote
Old 06-25-2003, 11:17 PM   #7 (permalink)
Boro Box Pilot
boroEF's Avatar
shane and i were thinking headgasket as well...but losing 100psi at just the headgasket? really?
that sounds pretty crazy to me
in any case i will rebuild the head, send it in for 3 angle valve job...and if i find some decently priced cams, i'll get a set of those too...and hello 3 digit whp territory
The boro guru
boro song
"boro boro boro
