I'm here to share what info I have came up with so far on my quest of going all LED, and the homemade units that I built. Contains hard core electronics talk.
First, some background.
After buying a pair of barrel-type 20 LED bulbs off ebay and used it across my two cars, I'm totally sold on going all LED. So I looked at how I can make my Camry so.
First stop is the light failure sensor. My grand goal is to mod it so that it will still sense a bad bulb while being able to not trip on a pair of good LEDs while still sensing one being dead, so I traced its circuit starting from the (99 Camry) EWD PDF I downloaded. Turns out to be very intricate involving a ASIC (I suppose because no datasheet is available on that Toshiba chip). Did I mention this piece costs C$320 from the dealer?
And a similar circuit built from
324 op-amps and a resistor network may not fit in the little sensor housing. Too much work. So I just pulled pin 4 out of the plug and called it a day, and in goes the two LED bulbs.
Now the turn signals. I know I need to conquer the flasher. For now I pulled the flasher off cam and took the flasher from Little Pig to do work while I study the former. The flasher comes with an adapter cap, with which I can use either ISO or JSO flashers on our cars. Both flashers and the adapter are interchangeable between gen 4 Camrys and gen 8 Corollas.
This is a much smaller circuit, but still with a odd purpose-built IC - thankfully there are a few similar chips on the market with datasheet. They are available for Atmel U643(B) and ST L9686. But a snag - the exact chip used in the flasher is neither, but they are similar enough that I managed to trace it out and understand how it works, and more importantly, allows me to formulate a plan to reconfigure the PC board to take a 555 timer chip instead.
After hacking the flasher I can go LED on turn signals. Now I need a pair of 3156 in the back and a pair of 3157 in the front, all amber. Again I want the barrel type for front (look at your gen 4 front corners and you'll know why), but the amber 3157s are too expensive.
My savior comes when I discovered that Active Surplus is stocking lots of 6000mcd 4-legged sqaure LEDs in amber and red, at 5 for $1
. And the same ebayer now sells the exact same bulbs that I bought at $8 a pair!
Time to buy another pair and stock up on those LEDs. Bought 20 last Saturday, came home, and found 3 of them to be red
. No problem, I'll find use for them. Bench tests shows that they drop 3V and can reliably withstand 85mA. Light up 3 of them together and it's enough to light up my room's ceiling.
Time to buy another pair at $8.
My plan is now to hack my flasher to run a 555 instead. Hopefully the relay coil will not take more than 200mA; I don't think I have enough space to add a transistor. I figured that 1k and 180k resistors plus a 3.3uF cap, assembled as a standard 555 oscillator circuit, will give me 92 beats/min, close enough to 85 beats/min of stock flasher.
If this works, I'll get a auto-spec SA555 for permanent use.
I also have some 9-LED 921 bulbs on order. Once done I'll have full LED tail in no time.
To be continued.
