Oil Filter Wrench - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 06-28-2003, 01:36 AM   #1 (permalink)
ECHO....Echo....echo....
BenG's Avatar
View BenG's Photo Gallery
Oil Filter Wrench
Okay...So I've decided to begin doing my own basic car maintainance and I'm going to change the oil on my Gen3 Camry. I've got everything worked out except for how to remove the oil filter on the 5sfe engine (inline 4). the strap type filter wrenches won't fit in the space where the oil filter is, so I've seen two other types of oil filter wrenches in my research online...one is like a cup that fits only specfic filter sizes, and the other one seems to be known as a "spider"-type adjustable filter wrench. Is this the wrench that I'm supposed to be using, or is there a specific type wrench that I have to get? Since I'm in Toronto, I'll be checking out CrappyTire tomorrow for a filter wrench, but if they don't have one that I can use, can you guys also let me know where I may be able to purchase the correct wrench? Thanks guys
BenG is offline   Reply With Quote
Old 06-28-2003, 04:29 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: Oil Filter Wrench
I use the cup type and I got at my local Toyota dealership.
They come in plastic (graphite?) and metal. Get the metal one.
"Skoolin' the unlearned!"
Old 06-28-2003, 05:12 AM   #3 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
what about those strap wrenches from crappy tire? those work great
plus you can use them on lots of other things, like to shut off your sink if you live in mile end (ugh)
-Nick
Nick is offline   Reply With Quote
Old 06-28-2003, 09:05 AM   #4 (permalink)
BenG's Avatar
I didn't think the strap wrenches would fit in the space where the oil filter sits on a 5SFE engine....
Old 06-28-2003, 09:15 AM   #5 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
I had a hard time using the strap wrench due to the location of the exhaust, so I got one of those cup ones. Really easy, they've got a socket for a ratchet so you can just kind of plug it in and go. I *have* used the strap wrench before so it is possible, but you have to place it just so on the filter so that when you pull to the side to tighten it, you don't run into the exhaust and pinch your fingers.
-- Jonathan W.
http://fleshy.org.nz/
brink is offline   Reply With Quote
Old 06-28-2003, 11:28 AM   #6 (permalink)
Boro Box Pilot
boroEF's Avatar
View boroEF's Photo Gallery
err why dont u use ur hands...i use my hands...it costs nothing
The boro guru
geocities.com/nuahs_cx my site about ae92, ef and track info
boro song
"boro boro boro
here we have a duct tape la la la
here we have an electrical tape du du du
here we have a coke can da da da
and then we have a downpipe!! boro boro boro"
boroEF is offline   Reply With Quote
Old 06-28-2003, 12:51 PM   #7 (permalink)
BenG's Avatar
And it's done! Oil change went fine, except that I had to roll the car up onto some folded over rubber mats so that the oil drain pan could be slid under the car...who knew that 1.25" lowering would actually cause clearance problems?? Next up, installing a strut tower brace later this afternoon...I'm on a roll baby!
As for using my hands, I'm afraid that I'm not that ghetto (would boro be the correct term, now that I know what it means?) mainly because I'm not man enuf to put my hand right next to a flaming hot exhaust manifold and trying to twist off the filter which is ALSO hot like a mofo from the oil and exhaust manifold heat....
Anyhow, thanks for all your help guys...
Old 06-28-2003, 03:51 PM   #8 (permalink)
Slowbie
View NOTSOFAST's Photo Gallery
Just let it cool down b4 u do the oil change !
NEVER RUN FROM A SNIPER. U WILL ONLY DIE TIRED !!
3RD GEN 94' CAMRY 2DR
NOTSOFAST is offline   Reply With Quote
Old 07-22-2003, 03:02 PM   #9 (permalink)
Scuzzle-butt
xavior66's Avatar
View xavior66's Photo Gallery
I know this may sound weird, but I didn't bother using an oil filter wrench. I just put on some old gloves so my hands wouldn't get dirty and "unscrewed" my oil filter (on '91 Camry). Make sure that when you unscrew it that you don't just take it out, but instead lower it some. A way to picture what I mean is imagine you have a cup (in this case, the filter) and you have the cup held down in front of the cooler to get some water (in this case, the cylinder head is the cooler). Hope this helps.
It's not what car you have, it's what you do with it that matters.
Packing your lunch in a paper bag-$5.00
Eating your lunch you bought on an airplane-$50.00
Losing your lunch from the airplane's cuisine, but not having a paper bag-Priceless
For everything else, there's paper bags!
xavior66 is offline   Reply With Quote
Old 07-22-2003, 04:29 PM   #10 (permalink)
View ineedhelp's Photo Gallery
I let it cool down for about half an hour and just use my hand, its not that hot and with enough strength applied, the grip of your hand does just well.
ineedhelp is offline   Reply With Quote
Old 07-22-2003, 08:28 PM   #11 (permalink)
4Aaron GE's Avatar
View 4Aaron GE's Photo Gallery
You know, I'm surprised none of you have suggested just driving a screwdriver through it and turning it that way. That would probably be the MOST boro way.
What? No animation? Bah.
4Aaron GE is offline   Reply With Quote
Old 07-22-2003, 09:56 PM   #12 (permalink)
Nick's Avatar
i've had to do that, but its my last resort
-Nick
Old 07-22-2003, 10:01 PM   #13 (permalink)
aka doublezero...
View wunderboy's Photo Gallery
I was just going to say that. If the filer is on so tight that I cant turn it with my hands, a screwdriver works well. You only need to hand tighten it after install.
There are those who do things, and those who take credit... The trick is to be in the first group, there is a lot less compitition.
wunderboy is offline   Reply With Quote
