Adjustable Cam Sprockets - what's the deal? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 06-30-2003, 12:49 PM   #1 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
Question Adjustable Cam Sprockets - what's the deal?
What do adjustable cam sprockets such as this:http://www.obxracingsports.com/perfo...18&subCat2ID=1 do? I understand the application of light-weight accesory pulleys and crank pulleys like these:http://www.obxracingsports.com/perfo...18&subCat2ID=1 and this: http://www.obxracingsports.com/perfo...18&subCat2ID=3 as reducing parasitic power-loss, is this the same idea as the cam sproket? Or is it suposed to adjust the timing (advance) for power gain? And if so would it work on a VVT-i engine? Is anyone running products like these?
Thanks,
Chris
Chris Corolla S is offline   Reply With Quote
Old 06-30-2003, 01:09 PM   #2 (permalink)
aka doublezero...
View wunderboy's Photo Gallery
adjustable cam gears let you advance, or retard your timing, based on your setup. You can adjust the timing with stock gears, but you have to take off the timing belt to do it, which doesnt make for friendly tuning.
There are those who do things, and those who take credit... The trick is to be in the first group, there is a lot less compitition.
wunderboy is offline   Reply With Quote
Old 06-30-2003, 01:14 PM   #3 (permalink)
I don't hate C3H8
rezzle's Avatar
View rezzle's Photo Gallery
Adjustable cam sprokets allow to adjust (fine tune) the valve timing *not* the ignition timing and valve overlap.
You just had to make me post a link to this page didn't you ...
don't fall asleep.
http://www.twelve100.com/faq%20and%2...haft_story.htm
Ricers - Imitate, Racers - Originate.
1989 Corolla GTS -4agze propane (rebuilding ... again)
2005 Subaru Legacy (we'll see if if lasts as long as the Yota's)
2008 Yaris
rezzle is offline   Reply With Quote
Old 06-30-2003, 02:52 PM   #4 (permalink)
Guitars and Cars
Well I read the link but it did not answer one of my questions:
O.K. so it allows you to adjust the valve timing? Doesn't that go hand-in-hand with ignition timing though? If you change the lift durtation or what have you, wouldn't you have to adjust the ignition timing as well?
Anyway I have Intelligent Variable Valve Timing so would this mod work since the ECU controlls valve timing? Plus my ignition timing is not mechanically adjustable (no dizzy, so plug wires, no coil), it is controlled by the ECU directly so wouldn't these things interfere with modding the valve and ignition timing to take advantage of say i/h/e...?
Old 06-30-2003, 03:52 PM   #5 (permalink)
I don't hate C3H8
rezzle's Avatar
First know that with VVTI you already have adjustable valve timing that is being controlled by your ECU and chances are you will be hardpressed to do better.
EDIT: The timing on between the intake and exhaust cams varys as much as 60!!!! degrees
On the track or on the rocks most performance engines use non stock ecu's in these cases the VVT is switched based on RPM or boost. Note i said VVT not VVTi because VVTI is not single stage. Performance VVTI ECU's do exist but they are very expensive, think WRC type vehicles.
I don't think that on a stock engine there is much to be gained by playing with valve timing. Bigger gains could be had by switching to cams with a more favourable lift and duration for the type of driving you are looking for. Don't forget that changing cams to gain power at the high end almost always means losing some of the streetable qualities of the engine.
Not only that but with these newer more complex valve systems (Toyota even has a special bolts on the thing so it can't be disassembled easily without 'their' tool) Mating camshafts can be rather troublesome.
This link discusses variable valve technology discussing its past present and what we will be seeing within the next few years.
http://www.mr2sc.com/websites/articles/vvt.htm
2008 Yaris
Old 06-30-2003, 04:04 PM   #6 (permalink)
I don't hate C3H8
rezzle's Avatar
Oh ...
forgot to mention.
The ignition timing and valve timing are still calculated separately, performance engines normally use a crank triggered ignition device. In your case I honestly have no idea how the spark is fired (cam triggered event or crank). I haven't bothered to read up on the newer Toyota's and I probably won't untill the Echo needs some serious work.
2008 Yaris
Old 06-30-2003, 05:52 PM   #7 (permalink)
Guitars and Cars
"First know that with VVTI you already have adjustable valve timing that is being controlled by your ECU and chances are you will be hardpressed to do better." Yes this is what I was getting at, I figured as much.
As for how the ECU advances the timing:
http://www.autoshop101.com/forms/h40.pdf
Old 07-01-2003, 12:01 AM   #8 (permalink)
Boro Box Pilot
boroEF's Avatar
View boroEF's Photo Gallery
vvti only controls the intake cam. if u got an adjustable cam sprocket u can use it on the exhaust cam.
should help u get some more power...wont do much tho unless u get some real cams
The boro guru
geocities.com/nuahs_cx my site about ae92, ef and track info
boro song
"boro boro boro
here we have a duct tape la la la
here we have an electrical tape du du du
here we have a coke can da da da
and then we have a downpipe!! boro boro boro"
boroEF is offline   Reply With Quote
Old 07-01-2003, 10:51 AM   #9 (permalink)
Guitars and Cars
Haha well it's not like I have 3 or four cams to choose from like a 4A-GE, there is no such things as cams for a 1ZZ-FE.
Old 07-01-2003, 11:04 AM   #10 (permalink)
Boro Box Pilot
boroEF's Avatar
errr i'm sure web has regrinds of it.
they have regrinds of everything!
The boro guru
boro song
"boro boro boro
Old 07-01-2003, 11:49 AM   #11 (permalink)
Guitars and Cars
regrinds=
Anyway it doesn't matter. I'm not trying to build my 1ZZ to drag or anything I know extracting horsepower from this plant is a fruitless endeavor beyond a certain point. I'm gonna get a TRD quick shifter for my birthday, that'l make me happy
Old 07-01-2003, 04:47 PM   #12 (permalink)
Boro Box Pilot
boroEF's Avatar
regrinds=
what's wrong with regrinds? u do know that back in the day, they didnt have billet cams right? everyone was using regrinds.
myths about them fucking up ur valvetrain and blablabla arent true. i know ppl to run regrinds on their ef's and track it etc etc with no issues whatsoever...on stock valvetrain!
The boro guru
boro song
"boro boro boro
Old 07-01-2003, 05:05 PM   #13 (permalink)
Guitars and Cars
Fine then you go get your cams re-ground, but read that link that Rezzle posted on 4A-GE cams first...
Old 07-01-2003, 11:26 PM   #14 (permalink)
Boro Box Pilot
boroEF's Avatar
who needs regrinds when u can get 20v :p
and remember, i'm boro...if i were to get cams, i'd go regrinds.
i didnt look at his links yet..but just from ppl's experiences it has been okay...at least on honda motors(they dont use shims and buckets)
The boro guru
boro song
"boro boro boro
Old 07-02-2003, 01:45 PM   #15 (permalink)
Guitars and Cars
Shuddup about hondas already How the hell does that apply to anything? No one here has a damm honda... Your 4A-GE is not a honda motor o.k.?!
Bad Boro! No V-Tech!
