VVT-i Head ? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 03-20-2007, 07:53 AM   #1 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
VVT-i Head ?
so i'm going to go out and buy me a extra sets of heads for my 96 1mz.
now i was wondering could a unit like camcon be able to control the VVT-i system. mainly can it control it with out feedback from the ecu.
^ and leaving it that way!
Old 03-20-2007, 10:29 PM   #2 (permalink)
Now with even more BOOST
View QuadCamSix's Photo Gallery
Yes and no
The VVTI can be run in open loop but you need a predictable vacume source. The 2JZ-GE has a massive vacume tank that you could use to actuate the VVT
The megasquirt can run VVT-i thorough its boost control feature in case you are considering an EMS.
MR2 V6 with an inordinate ammount of boost www.V6MR2.com
QuadCamSix is offline   Reply With Quote
Old 04-06-2007, 09:28 PM   #3 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
vvt-i can be controlled by anything that can modulate a signal. n2o controller, wastegate controller, fuel injector controller... Seems like a small (not bad) waste of money to me less someone wants to run big compression ratio pistons, or alot of boost.
For less than $100 more you can have a full blown piggyback that'll control ignition & A/F ontop of that.
You'll need the revised intake manifolds to go along with a head swap. And you'll want the corrisponding ECU to go with it, even if you don't run the thing. Some ugly things have happened in the past mixing MZ head & manifold components with one another.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 04-07-2007, 05:21 PM   #4 (permalink)
Toysrme's Avatar
Cool
Here is how vvt-i works in general. Thought that would help you.
Now with Turbo!
Old 04-16-2007, 07:28 PM   #5 (permalink)
Gangsta SC400 & 5.7Tundra
iTrader Score: 35 reviews
View -SCWEET1-'s Photo Gallery
Quick Question, How are you going to control vvt-i, if your car did not come with it? Do you have to change out the ECU also?
Toys, are you saying even an safc can do the work?
-SCWEET1- is offline   Reply With Quote
Old 04-16-2007, 10:38 PM   #6 (permalink)
Toysrme's Avatar
Cool
No, it requires something that can generate, or modify a form of PW signal, Even if it's based on a single frequency. An SAFC simply changes the voltage (resistance) of a signal.
An injector/solenoid/motor controller modulates in pulses. (Pulse Width Modulation = pwm)
Now with Turbo!
Head help Bonaro Pre-88 Toyota Pickup/Hilux 1 02-24-2007 02:52 AM
PART 1: 3S heads revised allblackalltrac Hardcore Tech and Competition 4 01-15-2007 04:49 AM
"A" engine info freakinbox Archived Corolla threads 29 05-10-2006 12:05 AM
Coolant Consumption After Head Gasket Replacement. Bullz_EyE Pre-88 Toyota Pickup/Hilux 4 05-06-2006 08:23 AM
