a little dumb question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 07-07-2003, 06:16 PM   #1 (permalink)
Den
86 Celica Gt driver
View Den's Photo Gallery
what is the difference between just rebuilding the head and rebuild the whole motor?
Den is offline   Reply With Quote
Old 07-07-2003, 07:22 PM   #2 (permalink)
Boro Box Pilot
boroEF's Avatar
View boroEF's Photo Gallery
rebuilding the head=redoing the head gasket, valve seals, cam seals, valve cover gasket etc...just any sort of gasket up there.
also possibly can entail new valve springs, new cams, new valves, new valve guides etc.
rebuidling the whole engine is what is stated above as well as rehoning the cylinder walls, new pistons and rings, new journals... it fixes compression if there is any compression problem in the block
The boro guru
geocities.com/nuahs_cx my site about ae92, ef and track info
boro song
"boro boro boro
here we have a duct tape la la la
here we have an electrical tape du du du
here we have a coke can da da da
and then we have a downpipe!! boro boro boro"
boroEF is offline   Reply With Quote
Old 07-07-2003, 09:13 PM   #3 (permalink)
aka doublezero...
View wunderboy's Photo Gallery
The head and motor are two seperate pieces, that do very different/seperate jobs. Rebuilding both is ideal, but can get costly, very costly if you purchase all new parts.
There are those who do things, and those who take credit... The trick is to be in the first group, there is a lot less compitition.
wunderboy is offline   Reply With Quote
Old 07-08-2003, 11:01 AM   #4 (permalink)
Den
86 Celica Gt driver
so if my compression of my engine is fine
after rebuilding the head, will I able to whole a turbo?
Old 07-08-2003, 01:30 PM   #5 (permalink)
View 2drcam's Photo Gallery
you could run a turbo now but depending how worn your engine is now you could ruin the motor the first time you floor the gas.
but to be safe if you put a turbo on your motor you would probably be safe running 5-7 psi of boost.
2drcam is offline   Reply With Quote
