Electric A/C
Alrighty, I've been going on a bit of a crazy idea trip for the past few weeks, so dont' flame me if this idea is completely whack. Who knows, maybe it'll inspire someone..hahaha! Anyhow, so since I have no clue about electric motors, I'm pretty sure that this idea will be nixxed real quick, but here goes nothing.
Would it be possible to run the A/C compressor with an electric motor instead of using the accessory belt? Maybe like piggyback an electric motor to the compressor unit and use either gears or a belt to connect the output shaft of the electric motor to the drive shaft of the compressor?
The only problems I can see right now is 1) that getting an electric motor of sufficient power would make the whole thing too heavy and cancel out any HP gains made from taking the A/C out of the accessory belt loop, 2) an electric motor of sufficient strength would be too large to mount by the engine, and 3) can a car's electrical system even handle the drain that would be needed to drive the electric motor?
I've been going on a little
