Bad Rod Bearing - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 07-10-2003, 11:07 AM   #1 (permalink)
View 92LudeSR's Photo Gallery
Bad Rod Bearing
On a 2000 Corolla with 200,000Km the car had a serious knocking, dropped the pan and found that the number 1 or 4? ( on the drivers side) rod bearing is gone, the rest look fine. Would you guys suggest changing all the bearings or just the worn one? Also would the engine have to be pulled or can we do it in the car.
Does anyone know a good source for bearings.
Is this a common problem with this engine or did we just get a bad engine. I always felt toyota engines would last much longer than this, the car is never raced or driven hard, mostly highway miles.
Depending on the price maybe a new engine would be a better choice than repairing any opinions on this?
Thanks,
Darrell
92LudeSR is offline   Reply With Quote
Old 07-10-2003, 11:18 AM   #2 (permalink)
Boro Box Pilot
boroEF's Avatar
View boroEF's Photo Gallery
just get it from toyota....do all of them at the same time.
ur pan is out and everything is dropped, why not?
The boro guru
geocities.com/nuahs_cx my site about ae92, ef and track info
boro song
"boro boro boro
here we have a duct tape la la la
here we have an electrical tape du du du
here we have a coke can da da da
and then we have a downpipe!! boro boro boro"
boroEF is offline   Reply With Quote
Old 07-10-2003, 08:09 PM   #3 (permalink)
View Deep's Photo Gallery
Its unusual for the rod bearings to fail at 200k on any Toyota, especially one that hasn't been abused. Did you keep up to date on your oil changes? Anyway, it would def be better to do all 4 at once, like Boro said, if the pan is dropped and everything is out of the way then there's no reason not to.
Deep is offline   Reply With Quote
Old 07-12-2003, 10:53 AM   #4 (permalink)
View JonWithTheCamry's Photo Gallery
the same thing happened to me on my camry with 170,000 miles on it. i didnt catch the problem soon enough and had to replace the crankshaft also. if the crank journal is still smooth then you can change the rod bearings without dropping the crank. just make sure you get everything meticuously clean
JonWithTheCamry is offline   Reply With Quote
Old 07-14-2003, 11:54 AM   #5 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
*choke*
ME<------------ has same engine
I haven't heard of this before but the 1ZZ-FE has only been out for a few years...
*crosses fingers*
Chris Corolla S is offline   Reply With Quote
Old 07-14-2003, 12:35 PM   #6 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
Actually Chris the 1zzfe has been out since 98 when it came out in the Corollas. Toyota's are notorius for every now and then an engine had a rod bearing that goes bad. When I rebuilt my engine on my 88 camry with 165K on it the number 1 cylinder(#1 is always the one closet to the timing belt/chain) it was toast luckily I didn't have to take the block and crank out I just cleaned up the surface plastigauged it and it was fine and put in new bearings. I also replaced my rings since I was putting in a new head which if I were you I would just pull the block and do a full rebuild on the engine. Once you seal one thing up it blows the other end up because the oil has to go somewhere so with you doing the bottom end your top end is going to go. So at least pull the head and repalce all the seals, gaskets and rings along with the rod bearings and doing that correctly you should be set for a lot more miles on her.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 07-14-2003, 01:55 PM   #7 (permalink)
Guitars and Cars
Yeah thanks I know how long the 1-ZZ has been out... I guess I consider 5 years not that long, it seems like just yesterday it was the end of 2000 and I had just bought my brand new Corolla. Time flys, now the original 50 miles is up to 44,000...
Chris
