Redrilling Rims... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 04-19-2007, 03:16 AM   #1 (permalink)
View shemicals's Photo Gallery
Redrilling Rims...
i got some sick rims and tires. 24's with low profile tires brand new and everything. I want to get them redrilled for a tacoma. where would i get chrome rims redrilled?
shemicals is offline   Reply With Quote
Old 08-20-2007, 12:11 AM   #2 (permalink)
View ir1d3d1rt's Photo Gallery
try a local machine shop.
ir1d3d1rt is offline   Reply With Quote
Old 08-20-2007, 10:03 AM   #3 (permalink)
Gameroom cash: $147537
Or try to find adaptor.
Old 08-20-2007, 07:25 PM   #4 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
or dont do it because its unsafe?
sell them... dont use them
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 01-27-2008, 12:24 AM   #5 (permalink)
View bob h's Photo Gallery
redrilling is perfectly safe with limitations
redrilling and changing wheel bolt patterns is no big deal. However there are limits as to what you can do. I do not suggest trying to do this yourself. It takes specialized equipment designed just for completing the task at hand. Changing an existing bolt pattern requires the use of pressed-in steel inserts. The actual finished product ends up being stronger than a wheel with the standard aluminum factory drilled seat. you might try the below link for more information. Hope this helps.
http://extremewheels.net/aaa.html
bob h is offline   Reply With Quote
Old 01-27-2008, 12:32 AM   #6 (permalink)
BANNED
View w203's Photo Gallery
that place sells the service, try getting an outside source for a review on redrilling wheels
the wheel bolt location are pretty close to each other to make a statement saying its not safe to redrill and have the new holes closer to each other. not to mention the added weight which means more strain on the holes. its possible yes, but safe? reliable? efficient?
w203 is offline   Reply With Quote
Old 01-27-2008, 08:22 AM   #7 (permalink)
OEM wheels are blank when they are cast. the wheel are drilled before they are painted or chromed. Aftermarket wheels done the same way. With that said many aftermarket wheels have two sets of differnet holes in them. To correctly answer your questions I would need to know more specific information about the wheel in question and the application change needed. Adding new holes to a wheel or changing the existing bolt pattern in a wheel is perfectly safe and efficient within limitations. When the car manufactures started using aluminum they used steel inserts for the holes. This practice changed to just conical seat holes drilled in the aluminum to cut costs. The use of steel inserts for the lug hole seat is starting a new surge as OEM again but only on high cars.
fix bent rims or get new ones? TRD_girl Archived Corolla threads 16 09-25-2007 10:16 AM
My expertise on rims and tires SpectraBlueCam Hardcore Tech and Competition 57 10-13-2006 11:54 PM
FS: 17" 5-Bolt Rims w/ 225/45/17 Winter Tires Eye8Pussies Car Parts for Sale 14 10-11-2006 09:57 PM
Opinions needed on some rims. HELP PLZ. WreckedSt Celica Forum 3 10-04-2004 05:29 AM
