Originally posted by funkstar69er
I am going to put in a 3SGTE motor in my 91 Camry which is the SV21, (3SFE), what will be some major herdals i have to get over to get the motor in and running saftley
The motor will go in and bolt up. All 3S blocks are the same just different internals.
Best bet is to get a clip that way you have everything you need to do the swap.
You have to do some rewiring in the dash. I'm not sure what needs to be rewired, but if you have a wiring diagram for a 3S-FE and 3S-GTE you can figure it out.
i know the basics of having to get a 3SGE gearbox, changing my back brakes from drums to disks, etc.
You can use the 3S-GE tranny, but I suggest that you upgrade the clutch and might as well do the flywheel too if its apart. Fidanza makes a badass aluminum flywheel for it.
You can leave the back brakes alone, but a conversion to disc brakes would be nice. You can use the parts off a V6 gen 2 Camry.
