I have recently put on a sports muffler, i just cut off my normal muffler and put this one on. And on take off i sound like a WRX then it kicks in and away she flyies. Can anyone help me!!!
Thanks Anthony
this is a pic of it
What do you reckon i could do with 5,000 coin? A 3SGTE !!
I'm sorry I lost something in how you described your problem. What exactly are you having trouble with?
Noise? Power at the bottom end?
Ricers - Imitate, Racers - Originate.
1989 Corolla GTS -4agze propane (rebuilding ... again)
2005 Subaru Legacy (we'll see if if lasts as long as the Yota's)
2008 Yaris
Well guys i am losing back pressure cause when i am taking off from the lights i am loosing against a fucking stock lancer, so yeah i think cause my muffler is just a fake one and it is a straight through pipe.!!!!! so yeah i am getting a 2 and a 1/2 from the cat back through the system.
yeah thanks guys,
Anthony
from what i've read about exhaust systems, and you saying that you dont want to lose backpressure, a 2.5" system may be too big. perhaps 2 1/4"? i have a 2" catback though i would have prefered a touch bigger.
this lancer, was it 1.8 or 1.6? if it was a late model 1.8, then our cars would be beaten.
Don't go too big with the exhaust unless you are turbo'd
2" is plenty.
The reason turbo's can use a larger exhause is because there is built in backpressure within the turbo iteslf, also the larger exhaust does help the spoolup time.
The reason you shouldn't go too big with a normally aspirated exhaust is because of the problems you are experiencing now. Just because a mod is good for the track doesn't mean it is good for your car As you have noticed sometimes the gains on the top end are not always worth the performance lost on the bottom end.
Good luck.
2008 Yaris
get 2.25 or 2.5 back and then make a smaller down pipe, if you still dont have the bottom end make the down pipe even smaller, u want all your exhaust restriction in the downpipe and header, this will make the most difference, once you get back past that your not going to help the bottom end as much and you will hurt the top end more
If your mechanic tells you you got a stuck piston and you're still able to drive your car, I'd change my mechanic as soon as possible because quite frankly, if he doesnt know a thing like that...what else doesnt he know
Maybe its time you changed your mechanic... hehe who knows what else he doesnt know... Abotu your loss of power, it could be your exhaust pipe, it might be that you lost some low end torque and it takes time to hit the powerband hence the "And on take off i sound like a WRX then it kicks in and away she flyies" and when you hit the powerband it zooms forward. Seems pretty much normal to me.
