Engine Code Problem Dealership Can't Fix - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 06-05-2007, 06:00 PM   #1 (permalink)
View gunkmurphy's Photo Gallery
4th Generation Engine Code Problem Dealership Can't Fix
Howdy. 1997 Camry XLE with 3.0L, 93K miles. P1705 code (direct clutch speed sensor) w/check engine light on. Bought car a couple of weeks ago and understand transmission was replaced with used one (43K) for same code. Discovered mechanic took out check engine bulb and declared it repaired. I replaced bulb, found code and took to Toyota dealer. Replaced direct clutch speed sensor (twice), jumpered wiring harness to ECU and replaced ECU...light and code still on. Toyota gave up and said maybe, but probably not, a remanufactured transmission would correct. Pulling the bulb is not an option as this is my daughter's car and I need it to work properly. Any ideas are greatly appreciated!
gunkmurphy is offline   Reply With Quote
Old 06-05-2007, 06:53 PM   #2 (permalink)
View toyomoho's Photo Gallery
The link below provides some info on this code. Suggest doing a further Google search on this code, the number of hits is large. The one other trouble issue listed was the wiring.
http://autorepair.about.com/library/a/1h/bl248h.htm
How does the trans shift, smooth, etc? Would not put another trans in at this time.
Who disconnected the light, the dealer that sold you the car? Removing the check engine light might be considered fraud and illegal where you live.
Old 06-08-2007, 02:27 PM   #3 (permalink)
thanks.....will try and ohm out this weekend. Toyota has open a case on this car to see if they have any more ideas
Old 06-13-2007, 10:39 AM   #4 (permalink)
View Just_Me69's Photo Gallery
The problem could be either a worn out clutch assembly in the transmission (read high gear but not OD) or the lock up clutch in the torque converter.
Just_Me69 is offline   Reply With Quote
Old 07-12-2007, 09:46 PM   #5 (permalink)
Toyota Technician
-=]KaiN[=-'s Avatar
View -=]KaiN[=-'s Photo Gallery
USA
I think your on the right track, if trans was replaced but not torque converter the same code would be there. Get more history on the repair at 43k. I had the joy of diagnosing a 4runner once that had a similiar code. Trans had been rebuilt same torque converter. I replaced torque converter and fixed the code. There is always the possibility of a harness problem.
-=]KaiN[=- is offline   Reply With Quote
Old 07-18-2007, 11:05 PM   #6 (permalink)
View BSM MOTORSPORTS's Photo Gallery
toyota tech
ok im a tech for toyota if they did the reman tranny then the conveter has been replaced what im guessing is that there is actually an intermited short i had this on a 03 highlander it took hours to find i would check the harness if not what dealer do you take it to i can get service history from them and graphs and such to figure it out
BSM MOTORSPORTS is offline   Reply With Quote
Rant from a Toyota Tech toyota_tech_01 Scion Forum 30 09-10-2008 06:02 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 01:45 PM
North County Toyota of Anaheim xpeed Toyota Dealers 3 09-27-2005 10:58 AM
Turn signal problem Chris990 Camry & Solara Lounge 3 04-02-2004 11:06 PM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 01:33 PM
