i've heard that all it takes to reset your ECU is to simply pull the (-) battery, and is the thing to do after a modification of any kind. is this true, what are the affects of not doing so, and does it really matter? the ECU automaticly makes adjustments whenever it detects any change, so why re-set it? tia
btw, are there any mods for my gen 1? its a 1998cc SOHC 16v if that helps at all...
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
The only reason to reset to the ECU would be to clear any trouble codes in the ECUs memory.
Otherwise, the ECU is basically always "adjusting" to the airflow and ignition variables that are throw at it (intake flow, exhaust flow, good gas, bad gas, shitty plugs, good plugs...etc). However in the repair manual (at least on an OBD-II car) there is a re-learn procedure that is recommended immediately after the ECU is reset. This is pretty much for a mechanics sake in the case that a customer complains about drivability after their car is returned from service.
Take that engine out and throw in a SOHC VTEC clip.
It's not what car you have, it's what you do with it that matters.
Packing your lunch in a paper bag-$5.00
Eating your lunch you bought on an airplane-$50.00
Losing your lunch from the airplane's cuisine, but not having a paper bag-Priceless
For everything else, there's paper bags!
88 LE: what did you have done to have your engine in prep for the turbo? the engine was the 2.2L right? and what turbo did you end up choosing? a GT-25? something smaller? and what was the performance gains?
...and where would i go about finding one of these??
VTEC engines are DOHC...
if so then what do u call the d16z6, d16y8........ :p
__________________ The boro guru geocities.com/nuahs_cx my site about ae92, ef and track info
boro song
"boro boro boro
here we have a duct tape la la la
here we have an electrical tape du du du
here we have a coke can da da da
and then we have a downpipe!! boro boro boro"
hmm..... thats interesting.... i'm thinking that if i ran a similar setup with a smaller turbo, possibly with a K03 or even a T3 as you did, just set at 8 psi, i might have the gains i was looking for out of this lightweight gen 1....
aprox. what was the total cost and time invested into this before it was almost finialized (can't say completly, the engine did blow...)? the 3S-FE is also an SOHC correct?
thanks for the pics and taking the time to anwser my questions. its greatly appreciated.
You can try a Mitsubishi TD-04 or TD-05, but their small turbos. A T3 looks big compared to em.
Total cost was about $1200.
Time invested was 2 days installing the turbo, making up the lines (stainless steel braided + AN fittings) for the turbo, making up the pipes (downpipe & compressor discharge pipe), test fitting everything, etc...
I also had to make a adapter to use a T3 turbo with the 3S-GTE turbo manifold. This took a few days to make cos I made it at the welding shop at school.
Total time invested was a few months. I did alot of research on turbos before I decided on a T3. I also had to buy all the parts I needed.
The engine blew cos I was running to much boost and the #4 piston melted.
My friends 5S-FE also blew on 10 psi boost. Cracked ring on #3 piston, scoring on cylinder #3 and #4, scoring on skirt of #3 piston, and melted ring lands on #4 piston. Pics at link below:
3S-FE is DOHC. Theres only 1 camgear though (on intake cam). The cams have scissor gears on them and the intake cam drives the exhaust cam through the scissor gears.
