tie rod end ball joint grease refill? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 08-06-2003, 02:57 PM   #1 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
last weekend i went over to my buddys and he had started changing his struts, but he hadn't seperated it at the knuckle, he took the whole friggin thing off
i just thought he had given himself a lot more trouble until putting it back together, i noticed the tie rod end had shot its load
can you refill the grease in there or do you have to change the whole tie rod end?
an acura legend up on a speed bump with a broken tie rod yesterday made me think of this, wouldn't want that to happen
-Nick
Nick is offline   Reply With Quote
Old 08-07-2003, 02:38 AM   #2 (permalink)
Nick's Avatar
anyone?
can they be greased or do you need a new one? how long could you go before it breaks?
-Nick
Old 08-07-2003, 03:13 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You have to replace the tie rod end.
"Skoolin' the unlearned!"
Old 08-07-2003, 05:53 AM   #4 (permalink)
aka doublezero...
View wunderboy's Photo Gallery
I'm not sure about your car, but basicly, if it has a nipple on the joint, you can grease it. If it dosent you gotta replace it. I think mainly only domestic cars have grease nipples on suspension parts.
There are those who do things, and those who take credit... The trick is to be in the first group, there is a lot less compitition.
wunderboy is offline   Reply With Quote
Old 08-07-2003, 03:01 PM   #5 (permalink)
View 2drcam's Photo Gallery
yup if it has grease fittings on them you can try to pump grease in there, but chances are they are shot.
2drcam is offline   Reply With Quote
Old 08-07-2003, 09:51 PM   #6 (permalink)
Nick's Avatar
well this isn't my car, its a mazda 323, but i'm pretty sure it dosen't have a grease fitting, looks like i got something to do this weekend again
-Nick
Old 08-09-2003, 11:14 AM   #7 (permalink)
Nick's Avatar
having a look at it, it dosent' look bad, there isnt' much play in it, anything i should look for?
it dosen't really clunk or anything while drivign... is it worth replacing now or should he wait till it breaks? or should there be warning of failure?
-Nick
Old 08-10-2003, 06:38 PM   #8 (permalink)
Turbo-Yota power
Jzs147-RR's Avatar
View Jzs147-RR's Photo Gallery
I use castrol MP grease and i fill it up unless its got water and rust in it.
5sfe powered turd ...
Jzs147-RR is offline   Reply With Quote
