another 5sfe turbo question
alrright i am thinking about doing a turbo set up on a 5sfe, and running 5 psi (maybe bump it up to 7 everyonce in a while for a little fun) i know i need the exhaust manifold and turbo off a 3sgte, and a little bit of custom exhaust work and piping, and as far as fuel manegment i have heard mixed results, some say go with
a) 2bar map sensor and some injectors from a supra
b) bigger fuel pump and the map sensor off the 3sgte
c) 10:1 fmu
d) i was thinking maybe use injectors, fuel pump, and map sensor off of a 3sgte
which ones would work? which would be cheapest? which would saftley handle 5psi of boost?
