Because how good of a turbo is on the 3SGTE?
If you get the second generation, it has a pretty decent turbo with split entry turbine for reduced lag. The JDM ones have a nice ceramic wheel. The main advantage is the engine, sensors, ecu, etc. are already set up for boost. Less screwing around in the long run.
theres a guy in the celica forums that dropped an avalon v6 motor in his celica. says its good but alot of tuning needed since the celica wasnt made for a v6 but if u ask me, its worth it for 200hp out of an n/a motor. turbo that bad boy and add a couple of bolt ons and that car would be bad ass. anyway, look in the celica section and look for a thread called "worlds first v6 celica" maybe the guy could help u out with wireing and tuning n shit like that.
I helped that guy put the engine in his car. It was kind of a b*tch.
We swapped in the 1MZ-FE engine and tranny. Had to modify the axles, engine mounts, radiator, frame cross members, upgrade fuel pump, and do a whole lot of soldering the two wiring harnesses together. That said, his car sets you back in the seat pretty well now. Hard to beat the 200+ lbs.ft. of torque across the whole rpm range of the engine. If you get the later models of 1MZ-FE, you can later get the smog legal supercharger
. Yeah, baby.
Bob Raby
Santa Cruz, CA
'88 Alltrac (broken)
FOR SALE
'87 4x4 Toy Truck
SOLD
'90 4Runner (3.4 swap, CA certified legal with K&N intake, modified thermal coated headers, 2.5" exhaust, and almost as fast as a stock 3rd gen
SOLD
