Originally posted by wunderboy
Well thanx for sett'n me streight there chris.... thats what I get for never owning a car newer than 1988....
Tell me about it. I went from an '84 Camry to a 2001 Corolla and I'm still learning new shit. At first I spent a lot of time reading the Hayne's Manual and staring under the hood scratching my head. The car has no distributer, no spark plug wires, and coil packs right over the plugs instead of one coil.
That reminds me the first time I did the brakes on this car I bled RR, LR, RF, LF and it was still a little soft. Then I read that new cars have a redundant braking system with two sets of lines instead of one and they are diagonal (so If a line gets cut you still have one front and one rear break) and with these brake systems you have to bleed RR, LF, LR, RF. After I did it this way the brakes were nice and stiff.
Here is a quote from an NSX web site which describes the same thing for a different car:
"We will be extracting the fluid from the bleed screw located on the top of each brake caliper. The service manual indicates that order matters, so we will begin bleeding the right rear (RR) first, then cross the vehicle to the left front (LF). Remember, the master cylinder is really a dual cylinder; the RR and LF brakes are operated by one and the LR and RF the other. We bleed the longest brake line first (RR) and complete the sub-system with the LF, then move on to the next longest line (LR) and complete the sub-system with the (RF). So, we're really bleeding two separate systems"
Maybe that will help here
