Taking out motor. Have question about engine wiring harness - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 08-18-2003, 01:11 PM   #1 (permalink)
View bennington28's Photo Gallery
The salvage yard that sold me the used engine cut up the engines wiring harness when they removed the engine. I don't understand why they just didn't cut the harness at the firewall.
I figure that I can either
1. remove the blown engines(in car) intake plenum
2. move the factory wiring aside
3. remove engine
4. install used engine minus its intake plenum
5. reinstall factory wiring and factory plenum on the used engine
or
1. cut factory engine harness at firewall
2. remove blown engine
3. install used engine.
4. reconnect wires cut at the salvage yard
5. solder and reconnect wires at the firewall
bennington28 is offline   Reply With Quote
Old 08-18-2003, 01:47 PM   #2 (permalink)
aka doublezero...
View wunderboy's Photo Gallery
What engine is this that your swaping?
I would go with remove all connections from old motor... label each one... set all wires aside. After you swap in the new one, go connection by connection, removing what they left on, and using what comes out of the harness at the firewall.
I wouldnt cut and paste your old and new harness, could be more problems then you want.
There are those who do things, and those who take credit... The trick is to be in the first group, there is a lot less compitition.
wunderboy is offline   Reply With Quote
Old 08-18-2003, 08:23 PM   #3 (permalink)
View jm_2thow's Photo Gallery
hey what kind of motor is it ? and does ne body have an extra gen 2 wiring harness and ecu, manual tranny for an 3sfe or 3sge (i have a 3sfe but will put a 3sge head on if i can get a 3sge harness)
jm_2thow is offline   Reply With Quote
Old 08-19-2003, 06:09 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Easiest way is to disconnect the wiring harness from the ECU, pull it through the firewall, and drape it over the engine.
Yank the engine out then remove the wiring harness. Lot easier to unplug everything when the engine it out.
Install wiring harness on new engine.
"Skoolin' the unlearned!"
Old 08-19-2003, 09:01 PM   #5 (permalink)
Blown engine is a 2.2 I4 from a 94 camry le. Used engine replacement is a 2.2 I4 from a 93 camry xle.
