can i use S-AFC? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 08-19-2003, 02:57 AM   #1 (permalink)
View crazy_camry's Photo Gallery
can i use S-AFC?
i'm turboing my camry (3s-fe), and as it is AFM'd i need something that will up the fuel along with the more air being forced in. if possible i would like to use the apexi product but i'm not sure if it would be suitable. any thoughts?
crazy_camry is offline   Reply With Quote
Old 08-19-2003, 10:38 AM   #2 (permalink)
View DIRTBIKEZ's Photo Gallery
Howard has running one on his gen2. I'm sure 88le will enlighten us.
'91 Camry DX
2.0L 3SFE Auto
R.I.P.
DIRTBIKEZ is offline   Reply With Quote
Old 08-19-2003, 06:25 PM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
I can see some potential problems with using a S-AFC on a boosted 3S-FE.
The ecu doesn't know that its seeing boost so for all its concerned your engine is still n/a.
Another thing is that a 3S-FE uses a AFM (air flow meter). The ecu uses this to calculate the airflow and the amount of fuel to add. The problem is that the AFM cannot see boost, so it can't compensate for the extra air from the turbo and add fuel.
Your best bet is to upgrade the fuel pump and use a fmu / boost dependent fpr or a aic (additional injector controller) with extra injectors mounted on the intake pipe before the throttle body.
"Skoolin' the unlearned!"
Old 08-20-2003, 01:47 AM   #4 (permalink)
bummer. would have liked the S-AFC with its little blue screen in the cabin (for pure ricey value ). i'll just get the Vortech like you did.
Old 09-29-2003, 12:23 PM   #5 (permalink)
View luisitol's Photo Gallery
a 5sfe can use an SAFC since it uses a MAP, right?
luisitol is offline   Reply With Quote
Old 09-29-2003, 01:09 PM   #6 (permalink)
View Deep's Photo Gallery
Yep
Deep is offline   Reply With Quote
Old 09-29-2003, 02:00 PM   #7 (permalink)
how many people have gone that route...jsut wondering so i could see what settings they are running
Old 09-29-2003, 02:24 PM   #8 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
you can still use a SAFC with an AFM metered car - it shouldnt, however, be your only course for air/fuel management.
ratko.org
Ratko is offline   Reply With Quote
Old 09-29-2003, 05:18 PM   #9 (permalink)
A few n/a MR2 guys have, dunno about any Celica or Camry guys.
Old 01-19-2005, 10:17 PM   #10 (permalink)
Guess whos back
View CamryWhat?'s Photo Gallery
BUMP UP Lol
Okay so i have a safc now and i wondering will i need a 2bar map sensor since i have the safc or will the safc be able to trick my ecu
also where can i find a wiring setup for the 5sfe ecu i can't find any on apexi.com!!!!
Help want to install tomorow if possible
2000 VW Golf: CAI Exhaust 18's Koni/Nuespeed
92 Camry- No motor Stock and Stock!
CamryWhat? is offline   Reply With Quote
Old 01-20-2005, 10:04 AM   #11 (permalink)
Guess whos back
anyone want to show me the ligh on this one?
Old 01-20-2005, 10:24 AM   #12 (permalink)
Gameroom cash: $147537
It depends.
The AFM don't need to see boost. As long as the air flow doesn't go over its measuring limit, the ECU will pump more fuel until it goes 100% on injectors. In fact you may not need the SAFC if the AFM can handle the extra flow.
What you can do is hook everything up. Use the SAFC to monitor airflow reading. Start with no boost and increase slowly until the airflow reading tops out. That'll be the max boost the AFM can handle.
You see, the SAFC increase fuel be increasing AFM reading. The ECU can see up to a certain AFM reading. Most likely at the AFM max out point, maybe a bit higher. The SAFC can't tell the ECU to pump any more fuel if its already maxed out.
Old 01-20-2005, 10:32 AM   #13 (permalink)
Guess whos back
well how do i hook the safc up to the ECU is the main goal here for today
Old 01-20-2005, 10:38 AM   #14 (permalink)
You'll need ECU pin out for your car. You'll not find anything in SAFC manual for 3S-FE. After you install, set the correct sensor type, most likely follow 3S-GE types. Worse case, trial and error. Car will just won't start if you set it wrong. Keep all setting at 0 until you have a datalog or other tuning device to monitor A/F. A/F gauge on stock O2 sensor doesn't count. You'll need wide band.
Old 01-20-2005, 05:59 PM   #15 (permalink)
View automatic's Photo Gallery
Without some additional fuel pressure, you may max out your stock injectors, if that's what you'll be using.
I thought the idea of having an S-AFC was to be able and use larger injectors, then re-tune.
automatic is offline   Reply With Quote
