How does reduced ZDDP affect new engines? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 09-01-2007, 03:39 PM   #1 (permalink)
View anneis's Photo Gallery
This is the "hardcore tech" forum so let's give this one a go.
The new API SM service lubricants have significantly reduced ZDDP after years and years of using it as a typical additive. Apparently it is reduced because it causes premature cat converter deterioration if the oil ingresses into the combustion chamber either by getting past the rings, down the valve stem/seal, or through a leaky turbo bushing.
The tradeoff is the risk of valvetrain wear. Here is one of the more intelligent postings on the matter, from: http://www.rochestercorvetteclub.org...?TID=12&PID=27
(Reprinted from "For Vettes Only", the monthly newsletter of the National Corvette Owners Association, by permission of the editor.)
Snake Oil?
For over a year, oil companies have been marketing American Petroluem Institute (API) approved motor oils blended with greatly reduced levels of zinc dithiophosphate (ZDDP) and other anti-wear additives like manganese and phosphate. This change in formulation was made because such anti-wear additives reduce the effectiveness of catalytic converters used on 1973 and newer cars and eventually damage them. ZDDP is also an air pollutant.
The first oils affected by new regulations calling for the additive levels to be reduced were those bearing the API’s Service Symbol and Certification Mark "SM". These are oils made for the latest generation of automobile engines. However, they are being marketed as if they were safe for ALL car engines. Now, there is much debate over whether this is true.
It has been discovered that the new SM oils provide less boundry lubrication and tend to increase sliding and high-pressure (EP) friction in the engines of older cars. This has led to such problems as the total failure of a new camshaft and a new set of valve lifters in a vintage sports car after just 900 miles of use. The engines most susceptible to such damage seem to be primarily those of the “flat tappet” type made in the 1960s and earlier.
When the parts involved in one failure were returned to the supplier, he went through the trouble of verifying that a molybdenum disulfide camshaft assembly lubricant had been used when the sports car’s valve train was re-assembled and that proper break-in procedures had been followed.
After checking with Delta Camshaft, the parts supplier learned that such failures have been more frequent since the API approved the use of the new oil formulations last year. Another company -- Crane Cams – is even recommending the use of an oil additive during break-in. Comp Cam’s Technical Bulletin no. 225 recommends using both an assembly lube and an oil additive.
Engine rebuilders believe that the reduced levels of zinc, manganese and phosphate are causing very early destruction of camshafts and cam followers. The American Engine Rebuilder's Association (AERA) issued Technical Bulletin No. TB2333 specifically to address this growing problem. Clevite, a major supplier of engine bearings, also says that it is aware of the problem.
Some automakers insist the first oil change is the only time additives are needed. However, those who service and repair older cars remain skeptical. Many recommend using new API CJ-4 diesel-rated oils -- such as Delo or Rotella – in older engines. These oils are generally available at auto stores and gas stations.
Redline Oil Co. says it is well aware of the older-engine problem and still uses the old levels of anti-wear additives in its products. Redline does not produce API-approved oils, so the company doesn’t have to comply to API guidelines. Redline is telling enthusiasts to use its street-formulated synthetic oil. Valvoline also offers an “Off-Road” 20W-50 oil that doesn’t comply to the new API formulations. Castrol, on the other hand, says that only its diesel-rated oils should be used in older cars.
Chevrolet is also aware of the problem. It recommends adding EOS oil fortifier at each oil change, which costs about $12 for an 8-ounce can. For cars that use “engine oil” in their gearboxes, General Motors sells an oil specifically formulated for Manual Gearboxes with Brass Synchronizers. Redline offers a similar product.
A lengthy article on this topic was written by Neil Maken and published in Skinned Knuckles magazine. It was reprinted in the Oct. 5, 2006 issue of Old Cars Weekly. To learn more about Maken’s article visit http://skinnedknuckles.net/pages/index.htm. **********
Let the discussion begin!
anneis is offline   Reply With Quote
Old 09-02-2007, 02:00 PM   #2 (permalink)
DCM
One with the farce
Gameroom cash: $106800
View DCM's Photo Gallery
I have heard this, too, but not to this depth. A friend of mine, who builds race engines, told me about the TB's from cam companies, as there were reports of camshaft failures even after following the assembly and break-in procedures to the letter.
So what's really going on? Is it a conspiracy by the oil companies and automotive manufacturers to cause the older vehicle engines to fail, therefore requiring the owners to buy new vehicles?
'92 ST185 All trac turbo
'92 AE95 wagon x2
'72 TE27
DCM is offline   Reply With Quote
Old 09-02-2007, 03:32 PM   #3 (permalink)
Don't think it is a conspiracy, but I do think it is crappy engineering and testing by the oil companies and manufacturers. They did not look at the old car market.
Go to www.sae.org and search on ZDDP. Countless research papers but always on new engines, nothing old. Maybe some of those scientists should hang out with gearheads.
Old 09-03-2007, 12:59 AM   #4 (permalink)
View 94_Rolla_Guy's Photo Gallery
It all has to do with more stringent emissions guidelines. Personally i have noticed that SM oils produce alot of valve noise in my families toyota's which after reading this i may be looking at a change
Right now my favorite oil is Castrol Syntec 0W-30 its pure real synthetic oil and is still a SL rated oil not to mention its a very good oil
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 10-31-2007, 04:08 PM   #5 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
contradicting don't you think...?
oil companies want you to buy newer cars that have 30 - 60 MPG compared to older cars that are like 10 - 20...?
therefore using less gas...?
no... its the tree huggers... they're are the reason why all engine will run on water and you'll have 1,000 MPG and 3 HP...
tHa kNiGHt FaLL is offline   Reply With Quote
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
The Difference between V, Inline, Flat, Rotary Engines xpeed General Discussion 31 07-10-2006 01:43 PM
most hp on a 22rte motor 79toy Pre-88 Toyota Pickup/Hilux 1 04-25-2006 08:57 PM
Making some cool power (caution! For reference use only ) AngryAE101 Archived Corolla threads 5 11-03-2003 10:03 PM
Corolla Engines for between 1988-1992 the_watcher_911 Archived Corolla threads 6 10-23-2002 12:34 AM
