need Help please 3vz Camry high idle - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 09-14-2007, 04:18 PM   #1 (permalink)
View Madhun's Photo Gallery
Just did a JDM swap in a 93 Camry.Cant find the cause of the high idle after and before warmup.Checked timing,for codes nothing amiss.What can i check next since i`m away from a shop? Pulled green CTS ,nothing changes.It idles at 13-1400,and when put in gear drops to 950rpm.Please give some ideas?I dont just want to throw switches at it.
thanks
Dave
Parts Manager
1-800-459-4418 ext 3
dave.rona@toyotawestohio.com
Madhun is offline   Reply With Quote
Old 07-08-2008, 02:28 AM   #2 (permalink)
Banned
View kurtdaniel's Photo Gallery
Originally Posted by Madhun View Post
Just did a JDM swap in an 93 Camry.Cant find the cause of the high idle after and before warmup.Checked timing,for codes nothing amiss.What can i check next since i`m away from a shop? Pulled green CTS ,nothing changes.It idles at 13-1400,and when put in gear drops to 950rpm.Please give some ideas?I dont just want to throw switches at it.
thanks
Dave
Notice if the idle drop back after the car is warmed up, if it does, the problem might be the coolant temperature sensor. Try to check it with a multimeter before replacing it to see if its good or not.
kurtdaniel is offline   Reply With Quote
Old 07-08-2008, 07:48 AM   #3 (permalink)
thanks but the car is long sold,
Dave
Parts Manager
Excessively Low Idle After Long Period of High Speed ('94, 4cyl) Corsulian 3rd & 4th Generation (1992–1996 & 1997–2001) 6 02-15-2009 05:48 PM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
Idle speed too high upon start up... how to fix??? highlander04 General Discussion 21 01-30-2007 01:43 PM
98 camry idle is high 9598toys 3rd & 4th Generation (1992–1996 & 1997–2001) 2 10-13-2004 10:06 PM
