A few 3s-fte questions for the gurus. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 09-27-2007, 03:54 AM   #1 (permalink)
Percentage's Avatar
View Percentage's Photo Gallery
So, I was looking into turboing the 3s-fe and I still have a few unanswered questions.
1. Is running water lines to a ct-26 necessary? I know many other turbos don't need/have them.
2. Will an oil restrictor be necessary, or does the ct26 have one built in. If so what is a recommened size for a -3an line.
3. Will the flapper afm need to be run on the boost side in order for the car to idle. I know when turboing an NA nissan, this is necessary.
4. Can I utilize stock injectors at 6 psi of boost with an fmu? Also, what ratio FMU?
5. Finally in terms of ingnition timing, should it be 1/2* per 1psi of boost pressure?
thx for the help in advance.
Percentage is offline   Reply With Quote
Old 10-04-2007, 02:25 PM   #2 (permalink)
Percentage's Avatar
bump.
I know you guys have turbo'd 3sfe's, any insight would be rockin'.
Old 10-09-2007, 12:52 AM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
turbo life decreases if you dont have them on a turbo that was designed for it.
-3AN is the size of the line, need of a restrictor depends on your oil pressure. I'm not using one on mine, just make sure your return line is BIG.
It shouldnt make a difference on what side its on. However you cant use a atmospheric BOV after the flap and thats where most people make the mistake. Creating an air leak will cause the car to not run properly.
Probably, FMU is a bandaid solution. Maybe a 1.3:1 ratio.
Good luck adjusting that without a standalone. I'd say start with 20degrees full timing
3SGE generation differences DodgeGarage Hardcore Tech and Competition 8 01-29-2012 04:16 PM
PART 1: 3S heads revised allblackalltrac Hardcore Tech and Competition 4 01-15-2007 04:49 AM
