stand alone systems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 09-04-2003, 11:14 PM   #1 (permalink)
View rollin95cam's Photo Gallery
stand alone systems
i have a 95 camry 2 door with the 5sfe and auto tranny. i am purchasing a turbo kit from a company in canada that utilizes the factory 3s manifold. i have also ordered rods, pistons, bearings, pretty much the works in order to be able to support over 16 PSI.my question is about management systems. i will either get 550 or 600 cc injectors and was looking to get an SDS EM4 stand alone system w/3 Bar MAP sensor to handle this but have been told that it will not work with my automatic tranny. does anyone know of any standalone systems that will work with an auto ?? it wouldnt be that big of a deal to swap in a 5 speed but if i do i will go over my budget which i have already gone over several times. Any help that anyone could give me would be greatly appreciated
rollin95cam is offline   Reply With Quote
Old 09-05-2003, 12:01 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Howbout a haltech system, they seem to be pretty good as far as I know, bit pricey but for sure the stock ECU wont support boosted conditions.
Old 09-05-2003, 07:21 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Accel DFI?
Friend has one on his supercharged Mustang.
Its badass.
"Skoolin' the unlearned!"
Old 09-06-2003, 01:36 PM   #4 (permalink)
View jm_2thow's Photo Gallery
you could pick up a manaul tranny from a junkyard for a decent price i bet, and it woudl be cheaper in the long run because i think if your going to be running 16 psi your going to be tearing up your auto tranny pretty bad
jm_2thow is offline   Reply With Quote
Old 09-06-2003, 02:56 PM   #5 (permalink)
View Deep's Photo Gallery
You could use the stock MR2 Turbo/Allltrac 3 bar map sensor, upgrade your injectors/fuel pump and stick with the stock ECU up to 7psi (fuel cutoff would be around there.) Then when you get the bugs worked out you slap on the SDS and crank up the boooost. And yeah, do yourself a favor, get a 5spd out of an MR2 Turbo or V6 Camry, E153 is the one you'd want.
Deep is offline   Reply With Quote
Old 09-06-2003, 04:06 PM   #6 (permalink)
View 2drcam's Photo Gallery
my question is...does the E153 tranny bolt right up to the 5sfe block.
could somebody please answer that????
2drcam is offline   Reply With Quote
Old 09-06-2003, 06:15 PM   #7 (permalink)
Yeah it does man.
Old 09-08-2003, 01:18 AM   #8 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
yes it does and you can even use any clutch/flywheel combo that is made for the Mr2. Only thin you'd have to do is mill out the flywheel bolt holes to align it with the holes on the 5s-fe.
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 10-02-2003, 11:49 PM   #9 (permalink)
View Nateness's Photo Gallery
what if he uses a MR2 N/A tranny? my MR2 uses a 5S-FE engine, and i believe it's the same set up as on the camrys? should be dirrect bolt on like it was designed that way... cuz... it was, just in my car for his engine = )
'91 MR2 N/A
Nateness is offline   Reply With Quote
Old 10-04-2003, 09:05 PM   #10 (permalink)
View ice and solo racer's Photo Gallery
For piggy back and stand alone systems check with canspeed.com,they can help you out way cheaper than all the other alternatives.
Tell them a guy named Tom passed on the info,might help a little who knows.
ice and solo racer is offline   Reply With Quote
