Removing a wire from a pin plug? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 11-01-2007, 08:04 PM   #1 (permalink)
Noob
View gladis's Photo Gallery
Hi all
I'm not sure if this is the right place to put this, but i have a plug from a Sienna and I want to remove a wire from it, and I want to know how.
Thanks in advance!
gladis is offline   Reply With Quote
Old 11-02-2007, 12:05 AM   #2 (permalink)
Pissed
View Camryamnesty's Photo Gallery
Ok, sometimes this can be a pain in the arse. i have never done one of these connectors before but most of a time there is a locking mechanism, which is clearly visible in your bottom pic. you need something to remove that. like a pick or something. Im not sure how it comes out but you can figure it out. Once you get that out. On the wire side of the connector, look inside the hole with the wire in it, there should be a little tab on the metal terminal, use a pick or something long and thin, and press the tab and pull the wire at the same time, and it should come right out. What is this connector for? I will look around to see if there is one in the shop that i can look at.
Camryamnesty is offline   Reply With Quote
Old 11-02-2007, 12:09 AM   #3 (permalink)
Noob
From another thread in the forum, this connector is right underneath the lower dashboard panel, right beneath the steering wheel.
Supposedly its to turn off the DRL, which my dad has been complaining about since he discovered that the headlights won't turn off.
I actually did try taking this apart before posting, with a screwdriver, the thing kind of lifted, but wouldn't actually come out.
Here's the thread: Disable DRL for my 01 Sienna
Old 11-02-2007, 01:39 AM   #4 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
Use a sharp pick and pop out that part that looks like piano keys. Then I think there's just a little finger that you have to lift up on and the pin will slide out. I use a dentist pick for this kind of stuff.
Pb is offline   Reply With Quote
Old 11-02-2007, 01:42 AM   #5 (permalink)
Noob
^^ Would the finger be inside the pin or the cover? I'm having trouble finding the pin. I popped the thing out (it doesn't come out, just sort of raises) but I don't see a finger
Old 11-02-2007, 04:21 PM   #6 (permalink)
Noob
Update: I got it! Now I have to see if it worked. The figure was on the connector side of the plug (not the wire) one of those watch screwdrivers got the job done. I am a happy customer. DRLs are off.
Old 11-03-2007, 11:19 AM   #7 (permalink)
Pissed
Yah sorry about that, i found one yesterday and remembered this thread so i checked and said oops lol
Old 11-03-2007, 04:37 PM   #8 (permalink)
Noob
^^ no problem, its thanks to forumers like you guys that I'm even able to figure the damn thing out.
HOW TO: 2005-06 Fog Light Modification SWTRDSPORT 2nd Generation (2005+) 110 10-24-2011 07:40 AM
Removing spark plug chip msteel Archived Corolla threads 7 04-16-2007 06:14 PM
Remote Start Help (Viper 160XV) LE05 Audio, Video, and Security - Tech 9 11-09-2006 03:26 PM
plug wire options???? is there?? DoomCrewInc Camry & Solara Lounge 8 01-26-2006 01:57 PM
Aftermarket alarm installation ?... Crowleys Camry Audio, Video, and Security - Tech 5 03-17-2005 06:10 AM
