Can someone explain how the TRAC traction control system works? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 11-10-2007, 05:59 PM   #1 (permalink)
View snipepod's Photo Gallery
I've asked many Toyota salesmen, and this question always seems to be over their heads.
I am considering purchasing a Matrix or Xd Scion. I live a steep driveway and live in snow country. My other cars are front wheel drive with open diffs (spider gears). When the driveway is slippery, the cars stall out, and one wheel (the one without traction) just spins, while the other does nothing.
Does the TRAC system have the brains to apply braking forces to the spinning wheel, and transfer torque to the other wheel (like a limited slip differiental)?
Or is the Trac system just a system where in drops engine rpm to prevent the one wheel from spinning. (Which is useless in my situation)?
snipepod is offline   Reply With Quote
Old 11-13-2007, 07:27 AM   #2 (permalink)
View toyotechwv's Photo Gallery
It actually does both depending on the severity of the detected wheel spin.
Shop Foreman L&S Toyota of Beckley
2008 Prius Package #2
1971 M35A2.....Tha Deuce
toyotechwv is offline   Reply With Quote
Old 11-13-2007, 10:09 AM   #3 (permalink)
How does it do that.
Thanks for the reply.
How can the TRAC system build hydraulic brake pressure at the spinning wheel if the driver does not have their foot on the brake pedal? Is there some type of electric servo and separate hydraulic circuit that is separate from the brake petal that has this ability?
Old 11-13-2007, 10:11 AM   #4 (permalink)
It uses the ABS actuator.
Old 11-15-2007, 08:31 AM   #5 (permalink)
TRAC and ABS
Could you go a little deeper into how the ABS actuator works? How does it build hydraulic pressure? I understand how the ABS uses either an optical or hall effect pickup at each wheel to detect wheel RPM and feeds it into the ECU (computer). What I don't get is how the hydraulic pressure is created to apply braking pressure to the low traction wheel.
Old 11-16-2007, 03:27 PM   #6 (permalink)
If you have Adobe Reader I can try to email you a diagram and full description.
Old 12-18-2007, 06:12 AM   #7 (permalink)
jet2757's Avatar
View jet2757's Photo Gallery
I would love to see the diagram.
jet2757 is offline   Reply With Quote
Old 12-18-2007, 07:08 AM   #8 (permalink)
I can email it to you.
All-New 2008 Toyota Highlander And Highlander Hybrid Raises The Bar humanoid Toyota News 12 10-15-2007 02:16 PM
Whiteline; Superpro and Dobinson Group Sale raptorracing Supporting Vendor Sales 222 03-09-2007 05:51 AM
ABS pulsing poker838 Camry Hybrid 20 03-08-2007 10:07 PM
DIY Cold-Air Intake bondobondo Hardcore Tech and Competition 40 11-24-2004 01:41 PM
My dash lights went out! xavior66 Camry & Solara Lounge 5 08-03-2004 01:38 AM
