Help! Avalon Fusible Link Removal - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 11-27-2007, 04:06 PM   #1 (permalink)
View 12voltkid's Photo Gallery
Okay techies, I know you are out there don't let me down. Upon almost completing a remote start install on my Pastor's 2006 Avalon, I was test fitting the air bag bracket and grounded out the starter wire. After a quick diagnosis I found that the #58 fuse (labeled Starter System) was blown, this fuse is part of the fusible link in the slot closest to the fender in the engine fuse block.
Here is my Q. I can not figure out how to get the fusible link out. I am hoping I do not have to pull the block and am looking for someone to help reduce my removal time. It looks like it should pull straight out but it is very tight. As an installer I have learned to ask before prying on plastic.
Please help me, I am in dire straights to get this car up and running again for my busy Pastor. Any schematics or drawings PDF or anything might also help in the answer.
Thanks So Much in advance
12voltkid is offline   Reply With Quote
Old 01-08-2008, 05:37 PM   #2 (permalink)
Pissed
View Camryamnesty's Photo Gallery
Gotta pull the bottom of the fuse block off. the fuse is bolted to 2 wires, and you gotta push the release on the fuse, and the fuse and 2 wires will com out when u pull on them. Should be bolted on with 2 10mm bolts
Camryamnesty is offline   Reply With Quote
Rear deck removal in 96 avalon 96Avalon_Matt 1st Generation (1995-1999) 6 09-26-2007 08:21 PM
Avalon shows dent in Toyota quality sciguy0504 Toyota News 98 03-25-2007 11:49 PM
'98 Avalon dash removal ricerrx7 Introduce Yourself Here 1 01-11-2006 01:00 AM
2003 Avalon Front Door Panel Removal avalondriver 2nd Generation (2000-2004) 0 12-10-2005 04:09 PM
Avalon or ES330? Pascal1961 General Discussion 8 07-21-2005 08:28 PM
