2.4L supercharged?! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 11-28-2007, 08:33 PM   #1 (permalink)
View seahunter54's Photo Gallery
2.4L supercharged?!
I currently have a '91 previa awd. The deal here is that in '94, toyota put a supercharger (s/c) in the previas. I would like to get a used '94 or newer 2.4L s/c from Japan and put in the '91 previa.
Is that possible?
What else would I need, besides buying a '94 or newer previa with a s/c?
I have family that own a mechanic shop so taking out the engine wont be a problem (I dont think).
seahunter54 is offline   Reply With Quote
Old 11-29-2007, 01:12 AM   #2 (permalink)
The Connoisseur
CharmCityES's Avatar
why not just swap the whole engine in? it wouldnt be much more expensive, and itll give you a fresh engine that will swap right in
The "Executive Sedan"
Old 11-29-2007, 07:56 AM   #3 (permalink)
Thanks, I figured that it would be the same motormounts and that it would fit right in. I can get an engine from Japan and that is what I plan on doing. But I am wondering if I need any other accessories such as a computer for the s/c?
Old 12-18-2007, 01:25 AM   #4 (permalink)
Rapid Roy's Avatar
View Rapid Roy's Photo Gallery
You can start by getting the factory manuals for both engines. You will need the wiring harness and ECU for sure from the SC. Beyond that, you are going to have to compare part numbers for things like drive shafts, CV joints. Also make sure that they use the same block and that the 2 previa's are from the same model generation. You can also google MR2 engine swap to give you an idea of what is involved.
Rapid Roy is offline   Reply With Quote
Old 12-18-2007, 09:35 AM   #5 (permalink)
Thanks Rapid Roy, this will be a great place to start! I knew that it was more than just a straight engine swap. Might just be better to find a 94 or newer previa that had a s/c and needs a new engine and buy that one?
FS: SUPERCHARGED 1998 Camry Conquest V6 Sedan Manual Alex(AUS) Vehicles 5 02-21-2008 12:12 AM
Supercharged (2zz-fe) Lotus mkII Toyota News 22 08-21-2006 08:32 PM
Maintainance questions for 2.4L kenandjenn 1st Generation (1995.5–2004) 3 06-09-2006 07:12 PM
MK1 Supercharged or MK2 Turbo Acer911 MR2 Forum 5 05-01-2005 03:05 AM
supercharged 2000 4runner, a good choice? aballard 4Runner Lounge 5 03-21-2005 08:54 PM
