i4/v6 tranny compatibility - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 09-23-2003, 06:16 AM   #1 (permalink)
View Meisner's Photo Gallery
I just read in a Celica forum that if you have a 5s-fe and want to turbo charge it, it was suggested to swap out the manual tranny for the one used in the v6 Camry. If this is correct, then a v6 Camry auto tranny should fit a 5s-fe as well.
Can anyone confirm this? I am looking at doing some major tranny mods (valve body pressure increase and torque converter mods) and would rather swap transmissions if one from the v6 would fit.
Thanks,
Steve
1996 Turbocharged Camry 5S-FE (4 cyl)
http://www.meisners.net/camry
Meisner is offline   Reply With Quote
Old 09-23-2003, 07:19 AM   #2 (permalink)
Turbo-Yota power
Jzs147-RR's Avatar
View Jzs147-RR's Photo Gallery
The v6 Camry trans fits onto the 5s/3s blocks might need to make some new holes on the bellhousing since not all the holes are the same.The i also think you might need the v6 hubs since the imput shafts are not the same.Then you use a 5sfe flywheel and a 1mzfe clutch should line up not exactly sure about the size of the clutch but surface area on the flywheel should be enough.BTW get back to me on AIM.
5sfe powered turd ...
Jzs147-RR is offline   Reply With Quote
Old 09-23-2003, 07:30 AM   #3 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
Double check to make sure the input shaft of the V6 auto tranny fits into the I4 torque convertor, or if the V6 torque converter meshes properly with the 5SFE flexplate... I KNOW for a fact that the V6 and I4 flexplate are not interchangable because of different bolt patterns. The bellhousings will bolt up, I think at least 5/7 should go in... some may not - so you may have to tap the block... if you are super anal about it.
Why keep messing with auto trannys and do a manual swap?
ratko.org
Ratko is offline   Reply With Quote
Old 09-23-2003, 07:33 AM   #4 (permalink)
Turbo-Yota power
Jzs147-RR's Avatar
Forget the autoslushbox trans ..
Old 09-23-2003, 09:44 AM   #5 (permalink)
I would do a manual swap in a heartbeat...except for one issue: The wife! She doesn't drive standard (and won't learn). Since this is also a shared car, I'd have to put up with all sorts of grief!
My other car (1988 Fiero) is a standard...I love driving that!
So it looks like if the auto tranny is to stay, I should look at Level Ten for valve body and torque converter mods.
Old 09-23-2003, 01:29 PM   #6 (permalink)
View 2drcam's Photo Gallery
yeah go to levelten.com and order yourself a auto tranny kit. that will be just as good.
2drcam is offline   Reply With Quote
Old 09-23-2003, 01:55 PM   #7 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
The solution is simple!
Ditch the wife!
Chris Corolla S is offline   Reply With Quote
Old 09-23-2003, 05:23 PM   #8 (permalink)
Careful...she'll come and hunt you down!!!
She loves the car too!
Old 09-24-2003, 08:59 PM   #9 (permalink)
prana's Avatar
View prana's Photo Gallery
if she really loves the car she would know whats good for it...
manual tranny!!!
99 Camry Le
prana is offline   Reply With Quote
